January 7, 2026 at 8:12 pm
swfisher
SubscriberThis is my first time using the ANSYS SIWave software and I keep receiving the same error whenever I try to run a simulation through the SIWizard (photo below). The imported PCB passes the validation check without errors and the error code occurs regardless of whether custom or default excitation sources are used. Does anyone have knowledge on how to resolve this issue? Happy to provide additional information about SIWizard parameters if helpful.
January 8, 2026 at 12:20 am
Takeshi Itadani
Ansys EmployeeIf you encounter the message "Class not registered" when running an analysis with SIwave's SIWizard, this is usually because a required component or library is not properly installed or is not registered in the Windows registry. Because SIwizard and TDRwizard reports are opened in the Ansys Electronics Desktop, this error can occur if the associated software or dependencies are missing.Â・Be sure to log in to Windows with administrator privileges.Â・Uninstall the existing SIwave from the Control Panel.Â・Restart your PC and clear any unnecessary temporary files and registry remnants.Â・Download the latest version of the installer from the official website or license management system.Â・During installation, right-click the installer and select "Run as administrator" and follow the instructions to complete the installation.Â・After the installation is complete, restart your PC again.ÂIf the problem persists, please also check the following:・Run Windows Update to keep your OS and related components up to date.Â・Check that libraries that SIwave depends on, such as the .NET Framework and Visual C++ Redistributable, are up to date. If necessary, reinstall them from the official Microsoft website.Â・Check that antivirus or security software is not interfering with installation or execution. -
January 8, 2026 at 1:43 am
swfisher
SubscriberHello,
Thank you for your response. I have checked and reinstalled .NET Framework and Visual C++ Redistributable, this had no effect. For some reason ANSYS (including SIWave and other applications) are not visible under Programs and features in the control panel. I tried using the ANSYS uninstallation program and reinstalling with the installer run as adminstrator but this did not have any effect. I should note that the way my University distributes ANSYS is through a Microsoft sharepoint containing folders for ANSYS electronics, fluids, etc. Inside the electronics folder there is an application named "setup" which lets me install the program.
January 8, 2026 at 1:46 am
Takeshi Itadani
Ansys EmployeePlease contact your university's IT department, as you may not have sufficient permissions or files added due to some restrictions being missing.
4858
1587
1386
1242
