September 7, 2025 at 11:28 pm
youssef.badran
SubscriberHello,
I ran a SAG mill simulation with breakage in Rocky for 25 seconds. Now, I’d like to remove the existing particles while preserving the worn geometry and then introduce a new set of particles.
Could you guide me on how to do this?
September 8, 2025 at 2:57 pm
youssef.badran
SubscriberHello,
I exported the worn geometry and used it in a new simulation. Even though the wear magnitude at time zero appears as zero (the wear data is lost), the geometry is worn at time zero.
September 11, 2025 at 1:15 pm
Lucas Bertollo Baggio
Ansys EmployeeGood. It is the same I suggested you to do in the topic:Â Continuing SAG Mill Simulation with New Particle Batch in Rocky
- affinity not set
1487
