June 11, 2025 at 3:34 am
scabo
SubscriberHi
I have drawn a contour plot and set the number of contours to 15. But I want to show only 5 values/ticks on the legend. How can i do it in CFDPost?
June 11, 2025 at 6:50 am
V.P
Ansys EmployeeHi,
You can control the number of legend ticks using the Range settings in the contour setup. But there won't be 15 contours, as it depends on the number of ticks you want. Here's how you can do it step-by-step:
Steps:
Go to your Contour settings (the same place where you set the number of contours to 15).
Look for the Range option.
In the Range section, select Value List instead of the default option.
When you select Value List, the "# of Contours" option will disappear, and you will see a new input field called Value List.
Example:
Let’s say the variable you are plotting (for example, velocity) ranges from 0 m/s to 6 m/s.
If you want to show 5 ticks on the legend, you can enter the following in the Value List:
0, 1.5, 3, 4.5, 6This will plot 6 contours, but the legend will only display these 5 values: 0, 1.5, 3, 4.5, and 6 m/s.
Summary:
Contours shown: 6Â
Legend ticks shown: Only the specific values you list (5 in this example)
Let me know if you want me to guide you through the exact menu clicks!
June 11, 2025 at 9:40 am
scabo
SubscriberHi thanks. But if i want 15 contours and want to display only 6 ticks. Can i do this somehow? Like by creating a new legend or something
6039
