September 3, 2026 at 11:25 pm
Amrith Mariappan
SubscriberHi all,ÂI am running a repeated-impact simulation chain and I cannot get thefull-deck restart to work in R14.1.1. I would appreciate any insight intowhether thermal-state restore on full restart is expected to work for acoupled S-ALE multi-material model with a phase-change thermal material,and whether the boundary-condition crash described below is a known issue.ÂSOLVER / ENVIRONMENT- ANSYS 2025 R2 (v252): lsdyna_mpp_dp_msmpi.exe and lsdyna_mpp_dp_impi.exe- Both report: LS-DYNA MPP double precision, Revision R14.1.1-16-gfadfb49b17 (MS MPI V10.0 and Intel MPI builds respectively)- Windows 10/11 x64, 16 MPI processes, double precision- Both the initial run and the restart use the same revision and the same number of processes, so the d3full version/rank-count requirements are met.ÂMODEL (initial run, "Impact 01")- 2D axisymmetric S-ALE, coupled structural-thermal:  *SECTION_ALE2D (ALEFORM=11, ELFORM=14)  *ALE_STRUCTURED_MESH + *ALE_STRUCTURED_MESH_CONTROL_POINTS  *ALE_STRUCTURED_MESH_VOLUME_FILLING (ALL / BOXCOR / ELLIPSOID with   velocity vector via VID)  *ALE_MULTI-MATERIAL_GROUP (3 AMMGs)- Materials:  *MAT_JOHNSON_COOK (MAT_015) + *EOS_GRUNEISEN for the HSLA-100 target  *MAT_ELASTIC_PLASTIC_HYDRO (MAT_010) + *EOS_GRUNEISEN for the WC   projectile (2220 m/s)  *MAT_ALE_VACUUM for the surrounding void- Thermal:  *MAT_THERMAL_ISOTROPIC_PHASE_CHANGE for the target (T09)  *MAT_THERMAL_ISOTROPIC for projectile and vacuum  *CONTROL_SOLUTION SOLN=2 (coupled)  *CONTROL_THERMAL_SOLVER SOLVER=12, EQHEAT=1, FWORK=0.9  *CONTROL_THERMAL_TIMESTEP / *CONTROL_THERMAL_NONLINEAR  *INITIAL_TEMPERATURE_SET (NSID=0, 296.15 K)- Boundary conditions via *BOUNDARY_SALE_MESH_FACE: SYM on the axis face (negx), NONREFL on the posx/negy/posy faces.- *DATABASE_BINARY_D3DUMP writes d3dump01/d3full01 at t = 5.3e-5 s.- *CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_ALE_ELEMENTS is used.ÂThe initial run terminates NORMALLY at t = 5.3e-5 s (4845 cycles) with aphysically sound thermal state (final temperature norm ~1.0e5, nonlinearthermal residual norms ~1e4-1e6). d3dump01 and d3full01.0000-0015 arewritten as expected.ÂRESTART RUN ("Impact 02")Full-deck restart deck = full model + *STRESS_INITIALIZATION (PIDO=10,PIDN=0, the S-ALE mesh part) + a new *ALE_STRUCTURED_MESH_VOLUME_FILLING(ELLIPSOID, with VID) introducing a second projectile. Executed with:  mpiexec -np 16 lsdyna_mpp_dp_xxxmpi.exe i=restart.k n=d3full01 memory=200mThe restart reads the dump correctly (problem time 5.3000e-5, cycle 4845,"material 10 in restart file initializes"), but then fails at the veryfirst cycle in TWO distinct ways:ÂFAILURE 1 - thermal solver divergence, Error 40359 (SOL+359):  "the minimum time step has been reached and the maximum temperature   change is greater than specified"  solution time 5.3000e-5, node 6234 (inside the previously impacted,  hot region of the target), temperature change 5.2976e+12. The first thermal solve after restart has an initial residual norm of 7.4432e+22, i.e. 18 orders of magnitude larger than any thermal solve in the healthy initial run (~1e4-1e6). During the Newton iterations the trial temperatures drop to ~112 K in material that ended the initial run hot. The residual is bit-identical whether or not the restart deck contains *INITIAL_TEMPERATURE_SET, so the initial-temperature card is not the cause - the thermal state after the restore appears inconsistent/ corrupted regardless of the deck.ÂFAILURE 2 - access violation in the 2D ALE non-reflecting boundary: When the NONREFL *BOUNDARY_SALE_MESH_FACE card is active, the run instead crashes at the first mechanical cycle with  forrtl: severe (157): Program Exception - access violation  NRBCALE2D (dyn60.F, line 36922) <- APPLY_LOADS <- FEM3D <- SOLTN With the NONREFL card commented out, this crash disappears (the run then reaches Failure 1 instead). The identical NONREFL setup runs without any problem in the initial (non-restart) run.ÂQUESTIONS1. On a full-deck restart with *STRESS_INITIALIZATION + n=d3full01, is the  nodal temperature field (and phase-change history) of a coupled  structural/thermal S-ALE model supposed to be restored from the dump?  Any known limitations for MAT_THERMAL_ISOTROPIC_PHASE_CHANGE on restart?2. Is the NRBCALE2D access violation on the restart path a known issue for  2D S-ALE non-reflecting boundaries? (I noticed the R14.1.0 release note  about an incorrect shear modulus in 2D S-ALE non-reflecting boundary  elements, and the R14.0.0 fix to *BOUNDARY_NON_REFLECTING_2D for  discontinuous boundary lines.)3. Is there a documented workaround other than abandoning the restart and  running both impacts as one continuous simulation (which is my current  fallback)?ÂFor context: under R16.1.1 the same model family crashes at cycle 0 with anaccess violation inside *MAT_THERMAL_ISOTROPIC_PHASE_CHANGE (alreadyreported separately), which is why this chain was migrated to R14.1.1.ÂI can provide the keyword decks, d3hsp/mes files, and (if useful) thed3full01 family as a reproducer.ÂThanks in advance,AmrithÂ
Viewing 0 reply threads
