January 2, 2026 at 6:35 pm
wetheyd
SubscriberHello
I am new to Ansys Electronics Desktop and it is my first time using Q3D, so I thought I would start simple.
I am trying to create a Coax cable, specifically RG58, TE part number 5021D1331, https://www.te.com/en/product-440005-000.html
TE has in the drawing specified the following properties:
Inner conductor: 0.0355", copper
Dielectric = 0.116", Rayolin F
Shield = 0.137", copper
Z0 = 50R
Capacitance = 30.8pF/ft
Resistance = 11.7 Ohms/1000 ftI created the 3D model following this tutorial:
And from the Q3D via tutorial "Q3D Extractor A 3D PCB Via Model.pdf"Now I got the Er of the dielectric from putting the values into this calculator: https://www.pasternack.com/t-calculator-coax-cutoff.aspx (Er = 2.155) which provies the correct capacitance at 30.8pf/ft, the Z0 is 48R and L = 72.2nH/ft
Now Ansys Q3D calculates the capacitance for 1 foot as 30.9pF which seems correct
Q3D calculates the inductance at 369nH which is quite far off 72.2nHIs it because I have not specified the shield as a return path?, what have I done wrong here?
Furthermore if I try and export the circuit, the transmission line looks like the following...
* BEGIN ANSOFT HEADER
* node 1 Â Â Conductor:Source1
* node 2 Â Â Conductor:Sink1
* Â Project: Cable_Coaxial
* Â Design: Q3DDesign1
* Â Format: Ansys Nexxim
* Â Topckt: Cable_Coaxial
* Â Creator: Ansys Electronics Desktop 2024.2.0
* Â Â Date: Fri Jan 02 18:15:30 2026
* END ANSOFT HEADER.subckt Cable_Coaxial 1 2
XZhalf1 1 3 Cable_Coaxial_half
XY1 3 Cable_Coaxial_parlel
XZhalf2 3 2 Cable_Coaxial_half.subckt Cable_Coaxial_half 1 2
V1 1 3 dc 0.0
R1 3 4 0.706636968706
L1 4 2 1.84528382349e-07
.ends Cable_Coaxial_half.subckt Cable_Coaxial_parlel 1
R1_0 1 0 2273086.54966
C1_0 1 0 3.15863088431e-12
.ends Cable_Coaxial_parlel.ends Cable_Coaxial
C1 is 3.15pF which I cant tell where it got this number from as its not in the SPICE matrix, and not near the 30.91pF I was expecting?
L1 is half the AC inductance, which is as expected.Â
EDIT: I added 2 more sinks, to each end of the shield, now my inductance is correct, but the capacitance is incorrect. Can I setup the sources and sinks so that I can calcualte both L and C at the same time?
Many thanks
Details below:
Dom
4858
1587
1386
1242
