January 20, 2025 at 10:54 am
abankusomari
Subscriberplease i am finding it difficult to locate pure iron material in ansys maxwell.can you kindly help?
January 21, 2025 at 10:39 am
Chinmay T
Forum ModeratorHello,
You can directly search with iron and select the the iron material from material libraries as shown in attached image.
If available iron material is not meeting your requirements then you can create your own custom iron (pure iron) material.
To create cutom material, In select definition window select the required material > click on clone materials > change the properties of the material > click OK and use it.
Please note that, selecting the material is an engineering decision. You can get the required properties of the material from the manufacturer for accurate representation.
Thank you,
Chinmay -
January 21, 2025 at 1:16 pm
abankusomari
SubscriberThank you Sir
- HFSS Incident Plane Wave excitement mode
- Ansys Maxwell 3D – eddy current
- Simulation of capacitor combining eddy currents with displacement currents
- dq graph non-conformity
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
- Parametrizing coil “terminals” with coil geometry
- Maxwell circuit – PWM
- Plotting Ex, Ey and Ez in vector forms individually
- Ansys-MATLAB Co-Simulation
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
1932
823
599
591
366
