3D Design
3D Design
Problems importing files from Discovery to Fluent Meshing
    • Kevin Beltrame
      HI,
      In discovery I set the length scale to "large" in order to model a large domain for my airfoil analysis. When I try to import this file into fluent meshing, the file has the attribute "millimeters" and the imported surface is only a 1000x1000 square (my domain si bigger). Instead, if I import a smaller geometry created using the length scale "standard" in discovery, the attribute in fluent meshing is "meters" (is correct). There is something that I can do in order to solve this problem?
Viewing 0 reply threads
