May 9, 2025 at 8:18 am
sikandarafzal499
SubscriberHi all,
I hope you all are doing well. I am currently facing an issue with the Ansys 202R2 version. First let me give a bit of overview of the issue.
I have 2 versions of Ansys on my PC, first one is 2023R1 which i only used for Mechanical or static side and also i have Ansys 2020R2 which i only use for fluent or CFX. the problem.When i try to open geometry in workbench 2020R2 i dont see any option to edit my geometry in Spacecliam or design modeler. But i have Spaceclaim 2020R2 installed on my pc and i can use it standalone. Can anyone please help me in this regard?
May 9, 2025 at 1:23 pm
Nilay Pedram
Forum ModeratorHello,
I will need some more context to this - was it working fine before?  -
May 12, 2025 at 10:45 am
sikandarafzal499
SubscriberNo this issue is from the start as if the geometry option is disabled in the workbench, if i double click the geometry to open the 3D design nothing happen. But when i check the spacaclaim 2020 R2 its installed and working fine, i can edit or design my model inside. But i cannot use it inside workbench.
6455
