TAGGED: aerodynamic-damping, ansys-cfx, frequency, wing
August 22, 2025 at 8:01 pm
gstzortz
SubscriberDear Ansys Team,ÂI am trying to predict wing's flutter with a less expensive computational method than 2WAY-FSI. I have seen a method about calculating aerodynamic damping (if AD>0 then system damped if AD<0 then flutter occured).Âi Have some questions:Â1)One kind of tutorial video is this: [ https://www.youtube.com/watch?v=cYjR...AC8Org7rDlYZ4 ] and i have this QuestionÂAt timestep: 10:17-11:05 I've seen an approach that involves performing a transient CFX analysis to derive the excitation frequencies of the structure (in that way i could know what natural frequency are close enough, in order to include them into simulations, and avoid unecessary simulations about modes,AoA and velocity).ÂHow can I replicate this in my own model? Do you know of any ANSYS tutorials that cover this method? Also, would I need to model the structure's geometry within the CFX analysis as well?Â2. Regarding Normalization: I've discovered how to extract the kinetic and strain energy for each mode through in Mechanical from this video [https://www.youtube.com/watch?v=sFNGXjlnIFQ&list=LL&index=1&t=189s ]. However, when applying the mode shape as a periodic displacement in CFX, I need to adjust the amplitude to 1% of the wingtip chord (as suggested in various papers). This is primarily to ensure the aerodynamic damping value remains constant (as suggested in various papers) and to avoid generating negative volume elements from excessive displacement. With that in mind, do you happen to know how I can calculate the energy magnitude for each mode shape at a specific amplitude value?ÂI appreciate any further insights you can offer—thanks for your help! -
August 26, 2025 at 5:43 pm
rfblumen
Ansys Employee1.) I wasn't able to follow the link provided. However, I'm assuming you're referring to determining the natural frequencies and associated mode shapes of the structure. This is done in Ansys Modal and is a prerequisite to performing a blade flutter analysis in CFX. Typically, a blade flutter analysis is performed using the first natural frequency (usually the first bending mode) of the blade. This natural frequency and associated mode shape are then exported from Ansys Modal in a format that can then be imported into CFX-Pre. This workflow is outlined in the Ansys Learning Hub course "Aeromechnics of Turbomeachinery Blading".
2.) In CFX-Pre, the amplitude of the mode shape needs to be sufficient to properly calculate the aerodynamic damping but not be so large that mesh folding occurs. A suggested value is some fraction of the tip clearance or, as you suggested, using 1% of the blade chord measured at the tip span. Since the goal of the blade flutter analysis is to calculate the aerodynamic damping over a range of engine orders for a given operating condition, knowing the energy involved in an oscillation period is not needed to achieve this. Given that the energy involved is also a function of the amplitude, and that the amplitude is somewhat arbitrary, it's not clear how useful this information would be.
5824
