July 7, 2026 at 3:26 am
2210912041_alamirsyah
SubscriberI ran a simulation of an Airlift reactor with variations in tube draft, using a mesh that formed boxes with sizes of 3 mm and 5 mm. I tried using a porous medium in the mixture, but it had difficulty converging. Then I used the Eulerian method, and it worked. However, the fluid did not penetrate the walls. The porosity value was correct. What I’m confused about is the direction; the inlet is located exactly in the center. Should the direction value be set to 1 for the remaining cells, or should it be set to direction 2?
July 7, 2026 at 8:41 am
Forum ModeratorDirection of what? Fluid shouldn't penetrate walls, they're supposed to stop fluid leaking.Â
For an inlet it's usual to assign either a "normal vector" to the flow or components.Â
1343
