PID vibration controller simulation
    • Md_Salem
      Hello, everyone,
      I am using ANSYS 25 R1 to simulate PID vibration controller of a cantilever plate. The sensors measuring STRIAN and the actuators are piezoelectric patches attached to the surface of the plate. I used coupled field transient module to do the simulation. I input 20 N impact force at t=0.0005 s, and the simulation continued until t=0.1 s. I then used the next APDL macro at the solution section to simulate the controller :
      "/post1
      set,LAST
      ex1=1675   ! element at which X-strain sensor 1
      ex2=1680  ! element at which X-strain sensor 2
      ey1=1153   !  element at which Y-strain sensor 1
      ey2=1165   !  element at which Y-strain sensor 2
      ! Weights update at each time step based on strain magnitudes
      *SET, fhigher, 185 ! Highest frequency (Hz)
      DT = 1/(20*fhigher) ! Time step
      *SET, TS , 0.1 ! Simulation time
      *SET, integ , 0 ! Integral term
      *SET, de , 0 ! Previous error
      *SET, uL , -150
      *SET, uH , 150 ! Voltage clamps
      *SET, eps , 1e-12 ! Small value to avoid division by zero
      *DO, t, DT, TS, DT
      ! --- Measure strains ---
      *GET,StrainX1,ELEM,1675,EPTO,X ! X-strain sensor 1
      *GET,StrainX2,ELEM,1680,EPTO,X ! X-strain sensor 2
      *GET,StrainY1,ELEM,1153,EPTO,Y ! Y-strain sensor 1
      *GET,StrainY2,ELEM,1165,EPTO,Y ! Y-strain sensor 2
      ! --- Compute dynamic weights based on absolute strains ---
      *SET, absX1 = ABS(StrainX1)
      *SET, absX2 = ABS(StrainX2)
      *SET, absY1 = ABS(StrainY1)
      *SET, absY2 = ABS(StrainY2)
      *SET, total = absX1 + absX2 + absY1 + absY2 + eps
      *SET, wX1 = absX1 / total ! Weight for X-sensor 1
      *SET, wX2 = absX2 / total ! Weight for X-sensor 2
      *SET, wY1 = absY1 / total ! Weight for Y-sensor 1
      *SET, wY2 = absY2 / total ! Weight for Y-sensor 2
      ! --- Combine errors with dynamic weights ---
      x = wX1*StrainX1 + wX2*StrainX2 + wY1*StrainY1 + wY2*StrainY2
      ! --- PID control ---
      *SET,kp =1e3
      *SET,ki =1e2
      *SET,kd =1e1
      *SET,kd =kd(0.00005/0.000263)
      *SET,integ = 0
      *SET, prev_err = 0
      integ = integ + x*DT ! Integral term
      diff = (x - de)/DT! Derivative term
      U = kp*x + ki*integ + kd*diff ! Control voltage
      ! Clamp voltage
      *IF, U, LT, uL, THEN, U = uL
      *ELSEIF, U, GT, uH, THEN, U = uH
      *ENDIF ! Apply voltage to PZT patch
      ESEL,S,ENAME,,226 NSEL,R,LOC,Z,1e-3
      D,ALL,VOLT,U
      ALLSEL
      de = x ! Update previous error
      TIME, t
      SOLVE
      *ENDDO "
      The first part of the simulation (the impact force effect) was done properly, and I could see the deformed shape in the solution section. But the previous code didn't run. When I look in the "solution information" section, I find an error.
      *** ERROR *** CP = 1.812 TIME= 17:40:29 Unknown label in field 5 ( EPTO ) of GET command. Line= GET,StrainX1,ELEM,1675,EPTO,X The *GET command is ignored.
      And then, the rest of the code didn't run. I need help to fix that error, please.
      Regards
    • Stella Peloni
      Indeed, this issue/Error comes from the fact that *GET command for elements (ELEM) does not support EPTO (total strain). In the Documentation, in this link, in Table 161,you can check all the valid Items for Elements, when using *GET commnand. EPTO item is valif as averaged nodal result on selected elements as follows:
      *GET,name,NODE, Node_Number,EPTO,X
      To be more precise, you need to select prior issuing *get command, the element of interest and then select the node of this element to *get the EPTO value.
      Thank you and have a great week ahead!
      Kind Regards,
      Stella
    • ravef63622
      If you are looking for a reliable casino https://www.casino-sistersite.co.uk/jackpotmobile/ with good returns, this is the place to go. I've been playing here for a few months now, and everything works stably. I often win small amounts, but the main thing - honestly and without cheating. Bonuses come regularly, especially nice to get personalized ones. Suitable for beginners and pros alike.
