The Ansys Innovation Space website recently experienced a database corruption issue. While service has been restored there appears to have been some data loss from November 13. We are still investigating and apologize for any issues our users may have as a result.
Non-intersected faces at interface – periodic
    • michal.czerwinski
      Hello, I have problems with setting up periodic in my combustion chamber.
      Geometry is a 60 degree piece of CC. I created geometry in spaceclaim both periodic surfaces have the same dimensions.
      I tried to set up periodic as rotational and with given offset 60 degress
      Firstly, I try to set periodic in fluent meshing, but I got error :
      also tried asymmetric mesh boundaries - didn't work either
      Then, I tried using fluent solver, but I got another error :
      My conclusion is that for some reason fluent doesn't recognieze relation beetwen surfaces. Do you have any ideas what I could set up wrong or which parameters should I check?
      Thanks for your answer
      Kind Regards
      Michał
      That should be OK. I assume the axis is set correctly? Also try -60 degrees as the order can matter in some cases.
    • michal.czerwinski
      Thanks for your reply, unfortunettly it didn’t help either. I may found the true problem though.
      Fluent can see that there are 2 periodic surfaces, when I measured geom in Spaceclaim we can see that the angle beetwen them is 60 deg. However when I tried to use auto offset mode, it showed warning. That suggest that the angle is diffrent. So now I wonder at what point could it happened? During meshing or during saving Spaceclaim file or somewhere else?
