TAGGED: combustion, fgm, heat-release, non-premixed-combustion, pdf-table, SDF
February 4, 2026 at 8:55 pm
georgesnaffaa246
SubscriberI am running a 3D transient combustion simulation with Ansys Fluent (2025 R1). I am using reduced order models (SDF and FGM), and I am computing the heat release rate.
At the start of the simulation, I am running into an issue: the heat release rate computed using the volume integral on my domain (PDF -> Heat release rate) is negative for the first 0.1-0.2s of the simulation, it remains constant at negative values for a while before it increases again, even when a flame is present. I have tested both the mesh and the timestep, and it does not seem to be the issue.Â
The setup is basically a cylinder filled with air at 25 °C, with a mass flow inlet (0.5 g/s) for fuel set at 900 °C, fuel composition is H2, CO2, CO, CH4 and C2H4.Â
Pressure-based solver with coupled pressure-velocity coupling, second-order implicit transient formulation.
Has anyone encountered such an issue before? If so, what could cause that? And what are some potential solutions?Â
Thank you
February 5, 2026 at 9:10 am
Ren
Ansys EmployeeCould you share some images of the combustion model setup in the "Species Model" dialog box (all the tabs), and also contour plots of the following:
- velocity
- mean mixture fraction
- progress variable
- temperature
- heat release rate
5049
1764
1387
1248
