September 18, 2025 at 9:16 am
c.meimaris
SubscriberI have a model of a cylindrical object. I define several load cases with spatially vaying radial pressure around the circumference. Each load case is defined in a separate time step. The multiplier for each time step is 1 for the step of interest and 0 for all others. I do this so that I can get the deflection for the particular time step I am interested in. I add them up later and manipulate them outside Ansys. This works fine for a single such load case. When I use 2 or more such load cases, the results from only the last load case (time step) are displayed properly. Allother load cases yeild 0.0 for deflection and stress. For example, If I have 6 spacially varying steps, then I get the correct results for step 6 but zero for steps 1 to 5. Ansys seems to lose the information for steps 1 through 5. I know that it is calculating the answers correctly for the last case becuase if I reduce from 6 steps to 3 steps, then I get the right answer for step 3 and zero for steps 1 and 2. Is this a bug anyone has seen before?
September 18, 2025 at 10:28 am
Erik Kostson
Ansys EmployeeHi
For this use soultion comination (combine different load cases as needed).
https://www.youtube.com/watch?v=2oLs7ES0hJc
All the best
Erik
- APDL, memory, solid
- Meaning of the error
3892
1414
1256
1118
1015
