August 27, 2025 at 7:38 pm
Sara.Ranjbareslamloo
SubscriberHello, I am working on capturing residual stress in two dissimilar materials using ANSYS Workbench. Since there is no direct module for dissimilar materials, I am simulating the transient thermal behavior and coupling it with structural analysis.
I have written a command for laser movement using a 3D Gaussian heat source, but now I want to extend it to handle multiple laser tracks. I attempted to use element birth and death for each track and apply the heat source individually. However, the issue is that all the commands are being applied simultaneously, whereas I need them to be executed sequentially at different times.
Does anyone have suggestions on how I can achieve this?
I mean I want to do exactly like this tutorial Additive Manufacturing with Element Birth & Death ANSYS Workbench (3D Goldak heat source)
here is my command for one laser trackÂ
g=0.3 !absorbityp=230 !Laser Power in wattsw=0.001  !radius of moving sourceA=(2*g*p)/(22/7*w**2)B=-3C=0D=900 !scan speedE=0F=w**2Â*DIM,HEAT_FLX1,TABLE,8,14,1,,,,0!! Begin of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F)*SET,HEAT_FLX1(0,0,1), 0.0, -999*SET,HEAT_FLX1(2,0,1), 0.0*SET,HEAT_FLX1(3,0,1), A*SET,HEAT_FLX1(4,0,1), B*SET,HEAT_FLX1(5,0,1), C*SET,HEAT_FLX1(6,0,1), D*SET,HEAT_FLX1(7,0,1), E*SET,HEAT_FLX1(8,0,1), F*SET,HEAT_FLX1(0,1,1), 1.0, -1, 0, 1, 2, 2, 19*SET,HEAT_FLX1(0,2,1), 0.0, -2, 0, 2, 0, 0, -1*SET,HEAT_FLX1(0,3,1),  0, -3, 0, 1, -1, 17, -2*SET,HEAT_FLX1(0,4,1), 0.0, -1, 0, 1, 20, 3, 1*SET,HEAT_FLX1(0,5,1), 0.0, -2, 0, 1, 3, 2, -1*SET,HEAT_FLX1(0,6,1), 0.0, -1, 0, 1, -2, 2, 21*SET,HEAT_FLX1(0,7,1), 0.0, -2, 0, 2, 0, 0, -1*SET,HEAT_FLX1(0,8,1), 0.0, -4, 0, 1, -1, 17, -2*SET,HEAT_FLX1(0,9,1), 0.0, -1, 0, 1, -3, 1, -4*SET,HEAT_FLX1(0,10,1), 0.0, -2, 0, 1, 18, 3, -1*SET,HEAT_FLX1(0,11,1), 0.0, -1, 0, 1, -2, 4, 22*SET,HEAT_FLX1(0,12,1), 0.0, -1, 7, 1, -1, 0, 0*SET,HEAT_FLX1(0,13,1), 0.0, -2, 0, 1, 17, 3, -1*SET,HEAT_FLX1(0,14,1), 0.0, 99, 0, 1, -2, 0, 0! End of equation: A*exp(B*(({X}-C)^2+({Y}-D*{TIME}-E)^2)/F)!-->sf,s1,hflux,%HEAT_FLX1% -
August 28, 2025 at 3:09 pm
dlooman
Ansys EmployeeBirth and death is only needed uf you are adding or subtracting material. It seems like you would have 3 functions and 3 SF loads, one for each track. Then in a transient analysis they could be solved for sequentially like below:
/soluÂ
antyp,trans
sf,s1,hflux,%HEAT_FLX1%Â
time,100Â
solve
sfdele,all,all
sf,s2,hflux,%HEAT_FLX2%Â Â Â ! 2nd trackÂ
time,200Â
solve
sfdele,all,allÂ
sf,s3,hflux,%HEAT_FLX3%
time,300Â
solve
September 2, 2025 at 4:55 pm
SubscriberHello,
Thank you for your reply, actually in addirive manufacturin (LPBF) which I am going to model it, the process is adding layers but I want to add in horizental (see the below link). In dding layers, it was ok I could define offset time in the equation in Y direction and using EBD model it, but for horizental I am not able to model it, I tried the code you wrote and add em for each track but just first laser track works and second/third track didnnt activated, also I tried to use another seperate command for that ; so I defined laser trackks in three different commans and anded the fourth command for applying the heat fluxes, but result was the same. just fist track moves and gives result.
September 3, 2025 at 2:13 pm
dlooman
Ansys EmployeeIf the issue is related to Additive it would be good to create a new post to possibly get a response from someone knowledgeable on Additive.
3817
1388
1188
1100
1015
