July 11, 2025 at 7:22 am
singh.112
SubscriberHI all,
I am working on modelling self-excited thermoacoustic instability in gas turbine combustor. I am using FGM combustion model with LES. However I am unable to capture any periodic behavious from the simulations as shown in experiments. With the same boundary conditions when I tried of using EDC with URANS, I was able to get periodic behaviour of the flame. Running EDC is computationaly very expensive I wanted to run FGM. Any help will be higly apprecited.Â
Thanks in advance.Â
July 14, 2025 at 3:15 pm
Ren
Ansys EmployeeHello,
Did you activate the "Compressibility Effects" PDF option in the Species model dialog box?
Are you using the "Turbulent Flame Speed" turbulence-chemistry interaction method?
July 14, 2025 at 3:27 pm
singh.112
SubscriberHello Ren,Â
Thanks for your response.Â
I did try the compressibility effects but it was giving periodic signal for even stable case. After seing the results, I went through the suerguide where it was mentioned that for significant pressure changes only we should use compressibility effects. I am not sure what should be considered significant pressure variation. Yes I did try turbulent flame speed approach but without compressibility effects. Without compressibility effects, I did not get any periodic signals.Â
July 14, 2025 at 3:38 pm
Ren
Ansys EmployeeFor thermoacoustics, the pressure-density coupling is important. So, the compressibility effects option is necessary.
The user guide is referring to combustion applications involving compressible flows (higher Mach number values).Â
July 14, 2025 at 4:17 pm
singh.112
SubscriberOkay I will just give a try one more time with turbulent flame speed.Â
Should I use ZIMONT or PETERS approach ?Â
July 16, 2025 at 8:10 am
Ren
Ansys EmployeeYou can use either. One may be better than the other depending on the fuels and flow configuration. Sometimes, it may also be necessary to tweak the model parameters.Â
3492
1057
1051
965
942
