December 19, 2024 at 10:00 am
chen.li.ellis
SubscriberWhen simulating the following model, set the skin depth layered based on the four sides of the rectangle.
And the simulation error is as follows
Maxwell2d solver, process solver2d error: Internal Solver Error: Â 'Segment in mesh was not found!'. Please contact Ansys technical support.Â
How to solve this error, thx.
December 23, 2024 at 11:56 pm
GLUO
Ansys EmployeeHi,
Is this an imported geometry or it is drawn inside Maxwell directly? Do you have any non-model objects or objects with "solve inside" unchecked?
GL
December 27, 2024 at 2:03 am
chen.li.ellis
Subscriberthx a lot. I find the problem.
I draw three polylines which are interfered with the model, and I set these three polylines to non-model to solve the problem.
1770
1387
1248
