August 6, 2025 at 11:23 am
a.y.al-wardi
SubscriberI’m working on a model where I’ve performed a Boolean subtraction (in DesignModeler) to remove internal components from a larger chamber. The Boolean appears to be successful as I can visually confirm the void region and there's only one solid body listed in the structure tree.
However, when I open the geometry in ANSYS Meshing, the internal surfaces from the subtracted region are still being meshed, even though the volume was removed.
What I have tried:
Performed Boolean subtraction properly (target body first, tool body second, “Keep tool body” unchecked)
Verified in section view that the void is present
Deleted/suppressed all leftover bodies
Confirmed that only one solid body exists
Exported the final result as a clean Parasolid (.x_t), and re-imported into a fresh Workbench project
Why is ANSYS Meshing still picking up and generating mesh on internal surfaces after Boolean subtraction?
Any suggestions on how to fully eliminate these would be appreciated.
August 6, 2025 at 12:09 pm
Forum ModeratorPlease post some images.
3597
1283
1107
1068
983
