mesh_skin operator in Mechanical DPF extracts contact elements – area doubled
    • felix.kaule
      Hello everyone,
      I’m using Ansys Mechanical 2024 R2  and want to calculate the surface area of my Tet10 mesh via the mesh_skin operator. However, the result includes contact elements (CONTA*/TARGE*), which leads to approximately twice the expected area.
      My Code:
      python
      skin_mesh = dpf.operators.mesh.skin(
          mesh=sub_mesh,
          mesh_scoping=node_scoping
      ).outputs.mesh.GetData()
      area_field = dpf.operators.geo.surface_area(mesh=skin_mesh).outputs.fields_container.GetData()[0]
      Expected: Only the true boundary faces of the Tet10 elements.
      Actual: Additional faces from contact elements are included.
      What I tried:
      • Filtering by mapdl_element_type_id via scoping.on_property
      • Using mesh.faces instead of mesh.skin
      • Explicit element vs. nodal scoping
      Question:
      How can I exclude contact elements from the skin mesh extraction so that only the structural boundary faces remain?
      Thanks in advance for your help!
      Best regards,
      Felix
    • Lydia
      Hi Felix,
      For DPF and scripting related questions, you should go ahead and ask in the Ansys Developers Forum Home - Community Forum
      Thank you for your understanding.
      Lydia
    • felix.kaule
      Hello Lydia,
      actually that's what I already did, you can delete this thread here if you want.
      Regards
      Felix
    • OmarWorthing90
      Poor Bunny
      Hello felix.kaule!
      from ansys.dpf import core as dpf
      # Filter out contact elements (e.g., type IDs for CONTA/TARGE are usually 100+)
      element_types_to_keep = [1, 2, 3, 4, 5]  # Structural types (adjust based on your model)
      filtered_mesh_op = dpf.operators.mesh.mesh_filter()
      filtered_mesh_op.inputs.mesh.connect(sub_mesh)
      filtered_mesh_op.inputs.element_type.connect(element_types_to_keep)
      filtered_mesh = filtered_mesh_op.outputs.mesh()
      # Now apply skin and surface area
      skin_mesh = dpf.operators.mesh.skin(mesh=filtered_mesh).outputs.mesh.GetData()
