Electronics
Electronics
Maxwell Linear Generator (Input Power < Output Power and losses?)
    • 2diamondm
      I’m running a 2D transient FEM simulation of a linear generator using ANSYS Maxwell. The simulation runs without any error or warning, but I’m facing a problem related to energy conservation and inconsistencies between different software versions.
      Main Issue:
      In ANSYS Electronics R2022, I observe:
      • Output power: 95.95 W
      • Input power: 99.33 W
      • Losses (Core + Solid + Coil): 6.129 W
      • → Total (Output + Losses) = 102.08 W, which is more than the input, violating energy conservation.
      In Maxwell 14.0 (same model):
      • Output power: 96.05 W
      • Input power: 100.28 W
      • Loss values were not available, but overall energy behavior was more consistent.
      Simulation Details:
      • Software: Maxwell 14.0 and ANSYS Electronics R2022
      • Model: 2D linear generator
      • Motion: Translational, Global Z, ±5.5 mm stroke
      • Speed: Constant at 1.727 m/s
      • Time step: 0.1 ms
      • Simulation time: 80 ms
      • Excitation: 220-turn coil
      • Circuit: R = 24.925 Ω, C = 226 µF
      • Boundary: Vector Potential = 0
      • Input power: Force_z × Speed
      • Output power: Current × Voltage
      • BH curve material: 35PN230 (nonlinear)
      • Losses used: CoreLoss, SolidLoss, StrandedLoss
      Additional Notes:
      • Increasing the time step from 1 ms to 4 ms caused output power to drop (96 W → 84 W), showing time-step sensitivity.
      • Mesh refinement had little effect on the output at 1 ms.
      • In a second test, increasing the magnet thickness (3 mm → 3.8 mm) gave a more realistic result (Input > Output + Losses).
      Questions:
      1. Why does output + losses exceed input power?
      2. Does R2022 compute losses differently compared to Maxwell 14?
      Any help or insights would be appreciated.
      Best regards,
      Muhammad Mohsin
Viewing 0 reply threads
