Electronics
Electronics
Maxwell AC Conduction not solving E-field in a region
    • sash
      I have a material in 2D Maxwell AC Conduction that has a nonlinear conductivity set as in the figure below.
      When I simulate, the E-field or voltage is not solved in this material, even though I check the box on the material to solve inside. I also set the insulator and conductor levels to 0 S for insulator and very high value for conductor. What else can I do to fix this?
    • MirandaH
      Hi, do you have excitation assigned on those two boxes?
    • sash
      I have excitation applied to the layer that it sits ontop of, but not on the two boxes itself.
