February 10, 2026 at 4:19 pm
joseph.filbert1
SubscriberI am new to Ansys Maxwell and I am trying to develop a script to post process results for a transformer based on the methods in [1]. As an example, my transformer has a primary and a secondary winding. Using parametric analysis I have two simulation cases: case one) primary excited with 1 amp of current secondary current set to 0, and case two) secondary excited with 1 amp of current and primary current set to 0. I am also sweeping frequency from fmin to fmax. The two simulation cases have different adaptive meshes because they have different excitations. For all frequencies, I would like to compute an integral over a defined surface using the results of both cases something like, \int{H_{1}\cdot\H_{2}^{*}\ddV}, very similar to an inductance matrix calculation. However, the integration domain should be restricted to everywhere except the transformer core.
It seems like I can use the field calculator "Write" function to save the case one field, then use the field calculator "Read" function to load the field and perform my integration with the case two fields. When I evaluate the integral, how does the field calculator handle the difference in mesh between case one and case two? Is the case one field interpolated at the mesh nodes of case two? Is there a better way to do this? Please see an example code snippet below,
My code snippet
#loop over frequency, full code would loop over coils as well L11, L21, L22
for ii in range(len(freqs))
#save case one field data to file
solution_name = "Setup1 : LastAdaptive"
variable_values = [
"Freq:=", freqs[ii],
"I_PRI:=" , "1A",
"I_SEC:=", "0A",
oModule.CalcStack("Clear")
oModule.EnterQty("H")
oModule.CalcOp("Smooth")
oModule.CalculatorqWrite("...HK.fld",
"Solution:=", solution_name
variable_values)
#load case one field data HK
oModule.CalculatorRead("...HK.fld", solution_name, "Fields",
variable_values)
#switch context to case two by changing variables
variable_values = [
"I_PRI:=" , "0A",
"I_SEC:=", "1A",
oModule.CalcOp("Conj")
oModule.CalcOp("Dot")
oModule.CalcOp("Real")
oModule.EnterSurf("Rectangle1")
oModule.CalcOp("Integrate")
results.values = oModule.GetTopEntryValue(solution_name, variable_values)
#write result to text file
[1] R. Prieto, R. Asensi, J.A. Cobos, J. Uceda, "A full procedure to model integrated magnetics based on FEA," IEEE, 2004.
February 11, 2026 at 8:45 pm
MirandaH
Ansys EmployeeHi, the meshes should be comparable from two cases, if the geometry is the same and adaptive requirements are the same. You can check mesh statistics to compare both designs.
5179
1838
1387
1249
