February 22, 2026 at 5:56 pm
julia00.huber
SubscriberHello,Â
I'm doing a thermal analysis of timber with gypsum boards during fire. I want to simulate the fall-off of the gypsum board after T_timber has reached a certain temperature. My code is running and calculating correctly, but now I want to change the material property data of timber after the fall-off. I implemented the switch, but now I get a jump in my temperature-time-curve in all depths of the timber after the change even if the temperature at that point is below 100°C (the change in the data only affects the data above 250°C). I have the same temperature points and the material property data is implemented correctly. Can someone help me, why this jump occurs and how I can fix it? It doesn't make sense that the temperature at a depth of 36 mm rises all of the sudden, only because the surface is now exposed. For the surface it makes sense of course.
 This is my solution code: I read the material properties before as material 3 and switch them after the trigger ( the fall off of the first layer can be ignored, currently I only use one layer and kill the second one emediately). I also get the same problem if I read the material data directly during the solution process.Â
def SolutionWithGypsumFalloff_AnsysComputation(mapdl, total_time,time_step,t_initial,T_ambient,h_fire,Gypsum_Node,Timber_Node,Tcrit_1st, Tcrit_timber, PD_gypsum_1, PD_gypsum_2,l_timber,save=True):  #Entering solution process  mapdl.slashsolu()  #Setting Initial temperature  mapdl.allsel()  mapdl.ic("ALL","TEMP",t_initial)  #Time stepping definition  #----------------------------------------------------------------------------------------------  mapdl.kbc(0) #ramped loads  mapdl.autots("OFF") #no automatic time steps  nsteps =int(total_time / time_step)  mapdl.nsubst(1,1,1) #no further substeps  #----------------------------------------------------------------------------------------------  depth_nodes = node_ids_at_depths(mapdl, PD_gypsum_1, PD_gypsum_2)  gypsum_1_killed = False  event_substeps = 50    Â  event_steps_after = 24   Â  event_steps_left = 0   gypsum_2_killed = False Â  times, Gypsum2_surface, Timber_surface,xnode_temp= [], [], [], [] #Collecting data  temps_by_depth = {y: [] for y in depth_nodes.keys()} Â  for istep in range(1, nsteps+1):    current_time = istep * time_step    mapdl.time(current_time)    #Setting Loads on Extra-Nodes    mapdl.run("D,100000,TEMP,%T_bulk%")    mapdl.d(100001, "TEMP", T_ambient)    # Set substeps: fine integration around the switch    if event_steps_left > 0:      mapdl.nsubst(event_substeps, event_substeps, event_substeps)      event_steps_left -= 1    else:      mapdl.nsubst(1, 1, 1)    #Solution for time-step    mapdl.solve()    #Collect temperature for checking    t_fire=mapdl.get_value("NODE",100000,"TEMP") #Temperature on Extra_node fire exposed side    t_cold=mapdl.get_value("NODE",100001,"TEMP") #Temperature on unexposed side correct?    T_gypsum2=mapdl.get_value("Node", Gypsum_Node, "TEMP") #Temperature gypsum surface    T_timber= mapdl.get_value("Node",Timber_Node,"TEMP") #Temperature timber surface    #Temperatures at depths    for y, nid in depth_nodes.items():      temps_by_depth[y].append(mapdl.get_value("NODE",nid,"TEMP"))    #Collecting data    times.append(current_time)    Gypsum2_surface.append(T_gypsum2)    Timber_surface.append(T_timber)    xnode_temp.append(t_fire)    #Check: Calculation during Loop correct?    #-------------------------------------------------------------------------------    print(f"Time: {current_time}s | Tfire(node100000): {t_fire:.2f}°C |T(100001)={t_cold:.2f}°C | Gypsum2 surface: {T_gypsum2:.2f} °C |Timber surface: {T_timber:.2f}°C") Â   Â    #Check: Fall-off criterion met?    #-------------------------------------------------------------------------------    if (not gypsum_1_killed) and (not gypsum_2_killed)and (T_gypsum2 >= Tcrit_1st): #(T_timber>=Tcrit_timber): #      print("1st gypsum layer failure triggered. Switching exposure to timber.")      #1) Kill gypsum board      mapdl.cmsel("S", "gypsum1_board_elem")      mapdl.ekill("ALL")      #2) Kill surf element on gypsum surface      mapdl.cmsel("S", "Fire_surf_gypsum1")      mapdl.ekill("ALL")      #3) Activate surface element on timber (now exposed)      mapdl.cmsel("S", "Fire_surf_gypsum2")      mapdl.ealive("ALL")      #COnvection and radiation on timber element      mapdl.cmsel("S","Fire_surf_gypsum2")      mapdl.sfe("ALL",1,"CONV",0,h_fire) #Define convection on surface element using film coefficient      mapdl.allsel() Â      gypsum_1_killed = True   Â    if (gypsum_1_killed) and (not gypsum_2_killed) and (T_timber >= Tcrit_timber):      print("2nd gypsum layer failure triggered. Switching exposure to timber.")      #1) Kill gypsum board      mapdl.cmsel("S", "gypsum2_board_elem")      mapdl.ekill("ALL")      #2) Kill surf element on gypsum surface      mapdl.cmsel("S", "Fire_surf_gypsum2")      mapdl.ekill("ALL")      #Change wood material properties to Kleinhenz values      #mapdl.prep7()      mapdl.finish()     Â      # 2) change material number for currently alive timber solid elements     Â      mapdl.prep7()      mapdl.allsel()      mapdl.esel("S","MAT","",2)   # timber (old material)      mapdl.esel("R","TYPE","",2)   # only PLANE292 solids (avoid SURF151)      mapdl.emodif("ALL","MAT",3)   # switch to Kleinhenz material      mapdl.allsel()     Â      mapdl.esel("S","TYPE","",2)      mapdl.esel("R","MAT","",3)      print("Alive elems with MAT=3:", mapdl.mesh.enum.size)      mapdl.allsel()     Â      # 3) back to SOLU      mapdl.finish()      mapdl.slashsolu()  Â      mapdl.antype("TRANS")      # 4) Transient-Optionen/Controls zur Sicherheit nochmal explizit setzen      mapdl.trnopt("FULL")      mapdl.nropt("FULL")      mapdl.kbc(0)      mapdl.autots("OFF")      #mapdl.nsubst(1, 1, 1)      #3) Activate surface element on timber (now exposed)      mapdl.cmsel("S", "Fire_surf_timber")      mapdl.ealive("ALL")      #COnvection and radiation on timber element      mapdl.cmsel("S","Fire_surf_timber")      mapdl.sfe("ALL",1,"CONV",0,h_fire) #Define convection on surface element using film coefficient      mapdl.allsel() Â      gypsum_2_killed = True      event_steps_left = event_steps_after  print("Simulation done")    Â  if save:    mapdl.save()  mapdl.finish()  return mapdl, times, Timber_surface, xnode_temp, temps_by_depth, depth_nodesI would be very grateful, if someone could help me!
February 22, 2026 at 5:59 pm
February 23, 2026 at 8:20 am
ErKo
Ansys EmployeeÂ
Hello
PyANSYS/PyMAPDL are open source -> supported via the github channels – please post your question there.
General question:
https://github.com/ansys/pymapdl/discussions
Of if an issue/bug:
https://github.com/ansys/pymapdl/issuesÂ
All the best
Erko
5179
1838
1387
1249
