LS Dyna
LS Dyna
LS-Dyna Workbench shuts down.
    • javat33489
      Hello everyone.
      I'm simulating a calculation with rubber and cord inside.
      Everything was working fine before, but now the calculation stops with an error and terminates.
      I'm using a 20-core MPP.
      I have a fairly powerful processor and 512 GB of DDR.
      Why is this happening and how can I fix it? Thank you.
    • Raman Babu
      Hello Javat,
      Are you getting the same issue when you are rerunning the same case?
      Did you check if you have enough space available?
      Also, there was no license/network issue at that time.
      If it happens every time, please try to rerun it with another LS-DYNA version.
      Raman Babu
