Local variable doesn’t update in UDF in DPM setup
    • Smruti R.
      I have written the following code for getting the total number of active particles in a domain (while using DPM in FLuent). The problem that I am facing is while printing the total number of particles, the moment the control comes out of the inner loop, the variable total_particles gets reinitialized back to 0 (even within the same function). Could someone please advise as in what is going wrong?
      I have tried putting total_particles as a global variable too, but that too didn't help.
      #include "udf.h"
      #include "dpm.h"
      /* Name of the output file */
      #define FILE_NAME "active_particles.txt"
      DEFINE_EXECUTE_AT_END(write_total_particles)
          int total_particles = 0;
          Particle *p;
          Injection *inj;
          /* Loop over all injections */
          loop(inj, Get_dpm_injections())
              Message("total particles = %d, inside loop 1\n", total_particles);
              /* Loop over all particles in the injection */
              loop(p, inj->p)
                  total_particles = total_particles + 1;
                  Message("total particles = %d, inside loop 2\n", total_particles);
          /* Write total count from node 0 */
          if (I_AM_NODE_ZERO_P)
              FILE *fpp = fopen(FILE_NAME, "a");
              if (fpp)
                  fprintf(fpp, "%f\t%d\n", CURRENT_TIME, total_particles);
                  fclose(fpp);
             else
                    Message("Warning : Hey there, Could not open %s\n", FILE_NAME);
    • Smruti R.
      To add more clarity to my current explanation, here is what happens.
      Let's say, there are 30 injections in total & every injection has a separate number of particles. Now, when the control completed counting the particles for the first injection, while coming out of the inner loop (i.e. loop(p, inj->p)), it should store the number of particles & that should be added to the number of particles in the subsequent injections. However, everytime, the control iterates through the injection loop (i.e. loop(inj, Get_dpm_injections())), the variable total_particles gets initialized to 0. And the total number doesn't add up.
      So, could someone please look into as in what's going wrong?
      Are you trying to count the total parcels in the domain or what's just been injected?
      • Smruti R.
        I want to calculate the total number of active particles in the domain (at a particular time step) & pass on that data to a file to get a time-wise variation.
      Are the DPM Report functions not sufficient?
      • Smruti R.
        The DPM report function mentioned in the “report definitions” tab only reports the injected mass & total mass in the domain, however, there is no way we can get the active particle numbers directly from the report definitions. While running the simulation, I do see the total number of tracked particles in the TUI (Console), but no way you can directly get the total number of tracked particles.
        Hence, I had to write a UDF to get the total number of tracked particles.
