lift and drag forces do not match Turek–System Coupling
    • sunilk
      The lift and drag forces do not match the results from the Turek–Hron's System Coupling example (example provided in pyansys system coupling); the difference is on the order of O(10²), although the tip displacements are quite close. What could be the reason for this discrepancy?
    • Essence
      PyAnsys questions are out of the scope of the Forum support. But other Forum users can pitch in to provide the suggestions. You can also post the PyAnsys questions on Git Hub.
    • Rahul
      Check if the participant's solutions and data transfers are converged. Post PyAnsys questions on Git Hub.
    • sunilk
      thanks
       i have posted this on GitHub Pyansys.
    • Essence
      Thank you.
Viewing 4 reply threads
