Issue with nodepairing using nearest neighbors
    • ubsxd
      Dear forum,
      In MAPDL, I am trying to couple nodes periodically. Therefore I select nodes on opposite faces (for example pos-x and neg-x), group and align them and use *moper to create nodepairs based on proximity (nearest neighbors). These nodepairs should then each be coupled. This approach works well with values that are equal between all coordinate systems (in my case the pos-z and neg-z), but there seems to be a mismatch somewhere when using nodes lying on a tilted plane. I will attach an example nlist printout of both groups in x-direction (pos and neg) as an image, as well as a code snippet I think to be relevant.
      I would greatly appreciate any kind of help!
      Code snippet:
      clocal,15,0,0,0,0,45,0,0
      csys,15
      *get,max_x,node,0,mxloc,x
      *get,min_x,node,0,mnloc,x
      length_x=max_x-min_x
      allsel
      tol=1
      nsel,s,loc,x,L/2-tol,L/2+tol
      nsel,r,loc,z,0-tol,0+tol
      cm,X_TOP_NODES,nodes
      nsel,s,loc,x,-L/2-tol,-L/2+tol
      cm,X_BOTTOM_NODES,nodes
      ALLSEL
      NSLE
      /solu
      nsel,none
      cmsel,s,x_top_nodes,node
      *get,nodnum,node,0,count
      *dim,coord,array,nodnum,3
      *dim,nodepairs,array,nodnum,2
      *vget,nodepairs(1,1),node,,nlist
      *get,ndmx1,node,,num,max
      *dim,ndat1,array,ndmx1,2
      *vget,ndat1(1,1),node,1,nsel
      *vmask,ndat1(1,1)
      *vget,ndat1(1,2),node,1,loc,x
      *vmask,ndat1(1,1)
      *vfun,coord(1,1),comp,ndat1(1,2)
      *vmask,ndat1(1,1)
      *vget,ndat1(1,2),node,1,loc,y
      *vmask,ndat1(1,1)
      *vfun,coord(1,2),comp,ndat1(1,2)
      *vmask,ndat1(1,1)
      *vget,ndat1(1,2),node,1,loc,z
      *vmask,ndat1(1,1)
      *vfun,coord(1,3),comp,ndat1(1,2)
      *voper,coord(1,1),coord(1,1),SUB,length_x
      cmsel,s,x_bottom_nodes
      *moper,nodepairs(1,2),coord(1,1),nnear,tol
Viewing 0 reply threads
