March 27, 2025 at 2:39 pm
longch
SubscriberThe same Lumerical 2024R2.03 version runs normally on Windows, but it encounters an error on the Linux system. Could you please advise on how to resolve this issue?We greatly appreciate your prompt assistance and look forward to your guidance.Âerror reports:
Traceback (most recent call last): File "/work3/longch/CHH/2DGC with ADJ/2DGC SM 12μm dx40 etch110SiO2 fr130 mfd10.4 1layer.py", line 182, in runSim_Adam(initial_cond, eps_min, eps_max, x_pos, y_pos, filter_R * 1e-9, working_dir, objective_function=J) File "/work3/longch/CHH/2DGC with ADJ/2DGC SM 12μm dx40 etch110SiO2 fr130 mfd10.4 1layer.py", line 72, in runSim_Adam optimizer_adam.run_optimization_stage() File "/work3/longch/CHH/2DGC with ADJ/lum_lib/optimizers/continuous_optimizers.py", line 58, in run_optimization_stage params, grad_adam, mopt, vopt = self.run_optimization_step(start_step=start_step_num, File "/work3/longch/CHH/2DGC with ADJ/lum_lib/optimizers/continuous_optimizers.py", line 74, in run_optimization_step g_adjoint = self.optimization_problem.callable_jac(params) File "/work3/longch/CHH/2DGC with ADJ/lum_lib/optimization_problem/continuous_optimization_problem.py", line 397, in callable_jac self.process_forward_sim() File "/work3/longch/CHH/2DGC with ADJ/lum_lib/optimization_problem/continuous_optimization_problem.py", line 259, in process_forward_sim self.check_simulation_was_successful(self.sim) File "/work3/longch/CHH/2DGC with ADJ/lum_lib/optimization_problem/continuous_optimization_problem.py", line 572, in check_simulation_was_successful raise UserWarning('FDTD simulation did not complete successfully: status {0}'.format(simulation_status)) UserWarning: FDTD simulation did not complete successfully: status 0.0 -
March 27, 2025 at 3:27 pm
March 27, 2025 at 5:53 pm
Kirill
Forum ModeratorDear Subscriber,
It seems the simulation was interrupted, but the reason is not clear.
- Would you be able to share the log file for the iteration that failed? Do you see any errors in it?
- Is this happening on the first iteration? Can you run just one simulation to completion (without optimization)?
- What version of Linux are you using? Is this issue occurring only on this Linux machine? Would you be able to check it on a different Linux machine?
- Is it a remote machine, and how do you connect to it?
- How did you set up the simulation resources on that machine?
- Have you tried running any optimization examples from our gallery? Did you encounter similar issues?
Best regards,
Kirill
Ansys Innovation Space
1057
1051
955
932
