3D Design
3D Design
Issue with geometry in Spaceclaim.
    • okanichidimma1203
      I'm using Ansys 2025 R1 student, the 2D rectangle I sketched in spaceclaim is not visible in the 3D mode. Can't figure out what's wrong, is there anything I have to twerk for it to be visible in 3D? Will appreciate any idea or guidance to this problem.
      Wish there is a way to attach the video of the process.
    • V.P
      Hi okanichidimma1,
      You have a 2D rectangle in SpaceClaim, but it is not visible in 3D view in spaceclaim? Maybe rotate the camera. You might be looking at the object from sideways.
    • okanichidimma1203
      Thanks for your input CFD_Friend, I have rectified the issue. It was a surface problem and happens because I didn't press the enter key after stating the dimensions before pulling to 3D mode.
