Ansys Free Student Software
Installation of Ansys v242 – Workbench does not appear
    • jpeppler
      I have installed Ansys v242 multiple times, and each time the only applications available are:
      ARC Configuration 2024 R2
      DCG Configuration 2024 R2
      RSM Clustering Monitoring 2024 R2
      RSM Configuration 2024 R2
      RSM Job Monitoring 2024 R2
      No Workbench, nothing to execute to get into the main application.
      I have attached the install.err log (see below) and the second is the install.log (see under install.err).   Anyhelp would be appreciated.   I have uninstalled, reinstalled, rebooted, made sure I had enough disk space, ran as system admin, added a system path variable as per one blog, still nothing.  One thing I have noticed in the error log is:
       couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe
      The file is NOT there, so I do not know why the installation application didn't extract it.  This error file has all the installs I have tried, and the last one is an uninstallation log I believe.,
      Please help!
      John
      --------------------------------------------------------------------------------  INSTALL.LOG
      Ansys installation: Fri Jan 10 13:09:00 2025
      Revision: 2024 R2
         ###### Error #######
         Error executing configuration script 'AnsConfigDiscoUnified.tcl'
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
         Registry key HKEY_CLASSES_ROOT\SpaceClaim.AnsysSCDM.242 or value creation error
         Error executing configuration script 'AnsConfigCommonDiscovery.tcl'
             Unknown error
         Exit Code: 1
         couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directory
             while executing
         "exec {*}$execCommand"
             invoked from within
         "if { $config == 1 || $unconfig == 1 } {
            set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCommonDiscovery.tcl" line 30)
         Error executing configuration script 'AnsConfigADR.tcl'
             Unknown error
         Exit Code: 1
             while executing
         "exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigADR.tcl" line 23)
         Error executing configuration script 'AnsConfigCommon.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCommon.tcl" line 32)
         Error executing configuration script 'AnsConfigWB.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigWB.tcl" line 23)
         Error executing configuration script 'AnsConfigSpaceClaimUnified.tcl'
             Unknown error
         Exit Code: 1
         Error executing configuration script 'AnsConfigCFX.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCFX.tcl" line 23)
         Error executing configuration script 'AnsConfigCHEMKIN.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCHEMKIN.tcl" line 23)
         Error executing configuration script 'AnsConfigEnSight.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigEnSight.tcl" line 23)
         Error executing configuration script 'AnsConfigFENSAP.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigFENSAP.tcl" line 23)
         Error executing configuration script 'AnsConfigCFDPost.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCFDPost.tcl" line 23)
         Error executing configuration script 'AnsConfigFLUENT.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigFLUENT.tcl" line 23)
         Error executing configuration script 'AnsConfigPolyflow.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigPolyflow.tcl" line 23)
         Error executing configuration script 'AnsConfigFORTE.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigFORTE.tcl" line 23)
         Error executing configuration script 'AnsConfigRDWorkbench.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigRDWorkbench.tcl" line 23)
         Error executing configuration script 'AnsConfigTG.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigTG.tcl" line 23)
         Error executing configuration script 'AnsConfigSpeos.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigSpeos.tcl" line 28)
         Error executing configuration script 'AnsConfigSpeosLabs.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigSpeosLabs.tcl" line 23)
         Error executing configuration script 'AnsConfigAQWA.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigAQWA.tcl" line 23)
         Error executing configuration script 'AnsConfigACP.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigACP.tcl" line 23)
         Error executing configuration script 'AnsConfigANSYS.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigANSYS.tcl" line 26)
         Error executing configuration script 'AnsConfigMotion.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigMotion.tcl" line 23)
         Error executing configuration script 'AnsConfigClientLicensing.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigClientLicensing.tcl" line 23)
         Error executing configuration script 'AnsConfigAVIEW.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigAVIEW.tcl" line 23)
         Error executing configuration script 'AnsConfigOptiSLang.tcl'
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 13:13:21 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 13:18:19 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 13:50:27 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 13:53:06 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 15:15:11 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 15:29:23 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 15:32:34 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 15:44:55 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Fri Jan 10 17:43:32 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Sun Jan 12 12:56:48 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigOptiSLang.tcl" line 23)
      Ansys installation: Sun Jan 12 13:59:58 2025
      Revision: 2024 R2
         'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCommonDiscovery.tcl" line 30)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigADR.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCommon.tcl" line 32)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigWB.tcl" line 23)
             Unknown error
         Exit Code: 1
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCFX.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCHEMKIN.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigEnSight.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigFENSAP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCFDPost.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigFLUENT.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigPolyflow.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigFORTE.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigRDWorkbench.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigTG.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigSpeos.tcl" line 28)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigSpeosLabs.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigAQWA.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigACP.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigANSYS.tcl" line 26)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigMotion.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigClientLicensing.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigAVIEW.tcl" line 23)
             Unknown error
         Exit Code: 1
             while executing
             invoked from within
            set cmdPath ""
            if { ..."
             (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigOptiSLang.tcl" line 23)
      /////////////////////////////////////////////////// INSTALL.LOG
      Start Installation: Fri Jan 10 00:05:03 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      Username of Installer: BIG-BOY-JONNY\jonat
      User Has Administrator Privileges
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp29396\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp29396 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Initial mount directory:
      Installation Directory:
      Windows x64
           Design
                Discovery
                Ansys Dynamic Reporting
                CFX (includes CFD-Post)
                Chemkin
                EnSight
                FENSAP-ICE
                Fluent (includes CFD-Post)
                Forte (includes EnSight)
                Model Fuel Library (Encrypted)
                Polyflow (includes CFD-Post)
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
                Discovery Geometry Interface
                SpaceClaim Geometry Interface
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Material Calibration App
                Customization Files for User Programmable Features
                Mechanical Products
                Motion
      The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
      This may take a while ...
      Successfully copied prerequisites from media.
      You're missing required prerequisites.
      Installing MS ASP.NET Hosting Bundle 6.0.23
      Installing MS ASP.NET Hosting Bundle 7.0.14
      Installing MS ASP.NET Hosting Bundle 8.0.4
      Installing MS Desktop Runtime 6.0.23
      Installing MS Desktop Runtime 7.0.14
      Installing MS Desktop Runtime 8.0.4
      Everything was successfully installed.
      Reading the installation media contents - please wait.
      You don't need to install any prerequisites.
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\framewrk\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\instcore\tcl\COMMON.TGZ ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\instcore\tcl\WINX64.TGZ ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythnew\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\disco\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\disco_explore\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\disco_overlay_resources\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\apiserver\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\clclient\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\ansoft\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\matdes\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\wb\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\corewb\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\cadaisol\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\cadregistry\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\injmold\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\minerva\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\meshing\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\primemesh\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\python_site_primemesh\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\apipsrv\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\syscplg\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\mechsrvplg\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins_simulationdatamodel\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins_autodyn\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\rsm\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\icemwb\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\turbosys\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\acispara\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\sec\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ccm\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\blademodeler\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\fusion\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ecadxltr\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\spatialiop\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\granta_gateway\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\granta_gateway\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\granta_selector\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\granta_selector\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cff\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluenta\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentc\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentm\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluents\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentp\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent3ddp\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\sgcharts\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fwgfx\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\common\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\commoninstall\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythext\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythcloudext\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\hlp\hlpviewer\HLPVIEWER.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\7zip\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-nvd3\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-ui-context-menu\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-ui-tree\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularjs\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularjs-slider\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularui\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\bootstrap\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\d3\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\ffmpeg\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\IntelCompiler\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\jquery\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\ngInfiniteScroll\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\nvd3\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\qt\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\signalr\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\hdf5\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\zlib\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\mpi\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ansys\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addgeometry\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\ansys\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\solver\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\data\DATA.GZ ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\apdl\APDL.GZ ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\python_site_mapdl\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\mech\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins_composites\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aas\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfxcomon\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\stride\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\hoops\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geompara\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\designmodeler\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\artemis\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\lumerical\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\intelmkl2023.1.0\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\nexus\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\openjre\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\spaceclm\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfx\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\cfx\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\post\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\cfdpost\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\cpprestsdk\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\chemkin\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\chemkin\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ensight\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fensap\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentu\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent2d\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent2ddp\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent3d\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\fluent\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ensight_components\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\polyflow\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\polyflow\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\matpro\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\forte\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\forte\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\turbogrd\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\acad\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\cat5\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\datakit\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\osm\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geomproe\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\pe\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\ai\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geomunig\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\nx\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\revit\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\se\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\sw\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speos\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\anscust\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speoslabs\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speosdata\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aqwa\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\aqwa\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\autodyn\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\autodyn\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\matcal\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\matdes\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\acp\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\acp\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\shapeoptimization\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\additive_cl\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\motion\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\motion_scdm_addin\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\student\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\license\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\config\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\hlp\hlplic\HLPLIC.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aview\WINX64.7z ...
        Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\optislang\WINX64.7z ...
      RSS is disabled
      Running ConfigSpaceClaim -install -discovery_live -create_discovery_shortcut
      Finished running ConfigSpaceClaim
      Running ConfigCommon -discovery_live -install
      Running ConfigADR
      Running ConfigCommon -install
      Configuring Help ...
      Running C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe ConfigHelp
         couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directory
      ANSYS Internet Doc has been configured.
      Running ConfigWB
      Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\AnsConfigRSM.exe" -encodingUTF8
      Configuring RSM...
      Configuring default RSM and ARC Port numbers for 24.2 ...
      Done!
      User has Administrator privileges
      Creating Start Menu Shortcut for RSM 24.2 Configuration...
      Creating Start Menu Shortcut for RSM 24.2 Job Monitor...
      Creating Start Menu Shortcut for RSM 24.2 Cluster Monitor...
      Creating Start Menu Shortcut for ARC 24.2 Configuration...
      Creating Start Menu Shortcut for DCG 24.2 Configuration...
      Error creating shortcut: There is not enough space on the disk.
      Running ConfigCFX
      Running ConfigChemkin
      Running ConfigEnSight
      Running ConfigFENSAP
      Running ConfigCFDPost
      Running ConfigFLUENT
      Running ConfigPolyflow
      Running ConfigForte
      Running ConfigRDWorkbench
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigSpeosLabs
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigMotion
      Running ConfigClientLicensing
      Running ConfigAview
      Running ConfigOptiSlang
      Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"
      Log files is C:\Program Files\ANSYS Inc\ANSYS Student\CADConfigLogs\v242\Latest\CADConfigurationMgr.log
      MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\CADConfigLogs\v242\Latest\CADConfigurationMgr.log
      Prerequisites ..... Configure Success
      SC  Workbench  PlugIn ..... Not Configured
      Discovery Workbench Plugin ..... Configure Success
      The installation completed with warnings/errors. Review any .err or .log files in:
      Installation Complete: Fri Jan 10 00:15:58 2025
      Start Installation: Fri Jan 10 10:23:54 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27468\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27468 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Configuring default RSM and ARC Port numbers for 2024 R2 ...
      Done!
      Creating Start Menu Shortcut for RSM 2024 R2 Configuration...
      Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\RSM Configuration 2024 R2.lnk
      Creating Start Menu Shortcut for RSM 2024 R2 Job Monitor...
      Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\RSM Job Monitoring 2024 R2.lnk
      Creating Start Menu Shortcut for RSM 2024 R2 Cluster Monitor...
      Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\RSM Cluster Monitoring 2024 R2.lnk
      Creating Start Menu Shortcut for ARC 2024 R2 Configuration...
      Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\ARC Configuration 2024 R2.lnk
      Creating Start Menu Shortcut for DCG 2024 R2 Configuration...
      Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\DCG Configuration 2024 R2.lnk
      Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\HPCServices\DCG Local Portal.lnk
      Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\HPCServices\DCG Local Shutdown.lnk
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 10:34:23 2025
      Start Installation: Fri Jan 10 13:07:46 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Successfully created file associations.
      Installation Complete: Fri Jan 10 13:09:00 2025
      Start Installation: Fri Jan 10 13:12:09 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos -removeProgramData
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 13:13:21 2025
      Start Installation: Fri Jan 10 13:17:07 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 13:18:19 2025
      Start Installation: Fri Jan 10 13:49:15 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 13:50:27 2025
      Start Installation: Fri Jan 10 13:51:55 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 13:53:06 2025
      Start Installation: Fri Jan 10 15:13:58 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 15:15:11 2025
      Start Installation: Fri Jan 10 15:28:12 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 15:29:23 2025
      Start Installation: Fri Jan 10 15:31:23 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 15:32:34 2025
      Start Installation: Fri Jan 10 15:43:40 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 15:44:55 2025
      Start Installation: Fri Jan 10 17:42:19 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Fri Jan 10 17:43:32 2025
      Start Installation: Sun Jan 12 12:55:35 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
      Windows x64
           Design
                Discovery
                Chemkin
                EnSight
                FENSAP-ICE
                Reaction Workbench
                TurboGrid
           Geometry Interfaces
           Optical
                Speos
           Structures
                Aqwa
                Autodyn
                Mechanical Products
                Motion
      RSS is disabled
      Running ConfigADR
      Running ConfigWB
      Configuring RSM...
      Done!
      Running ConfigCFX
      Running ConfigForte
      Running ConfigTG
      Running ConfigSpeos
      Running ConfigAQWA
      Running ConfigACP
      Running ConfigANSYS
      Running ConfigAview
      Installation Complete: Sun Jan 12 12:56:48 2025
      Start Uninstallation: Sun Jan 12 13:55:38 2025
      Revision: 2024 R2
      Platform specifics:
          Windows
      C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328 -launchdir "C:\Program Files\ANSYS Inc\ANSYS Student\v242" -admin -uninstall
          C:\Program Files\ANSYS Inc\ANSYS Student\v242\installer
      Design
           Discovery
           Chemkin
           EnSight
           FENSAP-ICE
           Reaction Workbench
           TurboGrid
      Geometry Interfaces
      Optical
           Speos
      Structures
           Aqwa
           Autodyn
           Mechanical Products
           Motion
        Extraction: C:\Program Files\ANSYS Inc\ANSYS Student\v242\installer\instcore\tcl\COMMON.TGZ ...
        Extraction: C:\Program Files\ANSYS Inc\ANSYS Student\v242\installer\instcore\tcl\WINX64.TGZ ...
      Processing selections for uninstall ...
        Attempting to terminate running processes whose images will be removed ...
      Successfully unregistered DLLs...
      Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe" -unconfigure_specified
      Running UnconfigSpaceClaim -install -discovery_live -create_discovery_shortcut
      Finished running UnconfigSpaceClaim
      Running UnconfigCommon -discovery_live -install
      Running UnconfigADR
      Running UnconfigCommon -install
      Unconfiguring Help ...
      Running C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe UnconfigHelp
      Running UnconfigWB
      Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\AnsUnconfigRSM.exe" -encodingUTF8
      Unconfiguring RSM...
      Running UnconfigCFX
      Running UnconfigChemkin
      Running UnconfigEnSight
      Running UnconfigFENSAP
      Running UnconfigCFDPost
      Running UnconfigFLUENT
      Running UnconfigPolyflow
      Running UnconfigForte
      Running UnconfigRDWorkbench
      Running UnconfigTG
      Running UnconfigSpeos
      Running UnconfigSpeosLabs
      Running UnconfigAQWA
      Running UnconfigACP
      Running UnconfigANSYS
      Running UnconfigMotion
      Running UnconfigClientLicensing
      Running UnconfigAview
      Running UnconfigOptiSlang
        Beginning file removal ... ...
      Uninstallation Complete: Sun Jan 12 13:59:58 2025
    • Rajeshwari Jadhav
      Please disable your firewall/antivirus and try installing again,the error shows tcl, which is caused due to firewall/antivirus.
      May I know from where did you download the package? Also rename the Ansys folder (%appdata%) and .ansys folder (%temp%) to Ansys.old and .ansys.old respectively.
