January 12, 2025 at 8:13 pm
jpeppler
SubscriberI have installed Ansys v242 multiple times, and each time the only applications available are:
ARC Configuration 2024 R2
DCG Configuration 2024 R2
RSM Clustering Monitoring 2024 R2
RSM Configuration 2024 R2
RSM Job Monitoring 2024 R2
No Workbench, nothing to execute to get into the main application.
I have attached the install.err log (see below) and the second is the install.log (see under install.err).  Anyhelp would be appreciated.  I have uninstalled, reinstalled, rebooted, made sure I had enough disk space, ran as system admin, added a system path variable as per one blog, still nothing. One thing I have noticed in the error log is:
 couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe
The file is NOT there, so I do not know why the installation application didn't extract it. This error file has all the installs I have tried, and the last one is an uninstallation log I believe.,
Please help!
John
--------------------------------------------------------------------------------Â INSTALL.LOG
Ansys installation: Fri Jan 10 13:09:00 2025
Revision: 2024 R2Â Â ###### Error #######
  Error executing configuration script 'AnsConfigDiscoUnified.tcl'
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
  Registry key HKEY_CLASSES_ROOT\SpaceClaim.AnsysSCDM.242 or value creation error
  Error executing configuration script 'AnsConfigCommonDiscovery.tcl'
    Unknown error
  Exit Code: 1
  couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directory
    while executing
  "exec {*}$execCommand"
    invoked from within
  "if { $config == 1 || $unconfig == 1 } {
   set config_dir "$installDir\\v$revn\\commonfiles\\configs\\$env(ANSYS_SYSDIR)"
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCommonDiscovery.tcl" line 30)
  Error executing configuration script 'AnsConfigADR.tcl'
    Unknown error
  Exit Code: 1
    while executing
  "exec "$config_dir\\config\\AnsConfig.exe" $ansConfigFunctionToExecute"
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigADR.tcl" line 23)
  Error executing configuration script 'AnsConfigCommon.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCommon.tcl" line 32)
  Error executing configuration script 'AnsConfigWB.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigWB.tcl" line 23)
  Error executing configuration script 'AnsConfigSpaceClaimUnified.tcl'
    Unknown error
  Exit Code: 1
  Error executing configuration script 'AnsConfigCFX.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCFX.tcl" line 23)
  Error executing configuration script 'AnsConfigCHEMKIN.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCHEMKIN.tcl" line 23)
  Error executing configuration script 'AnsConfigEnSight.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigEnSight.tcl" line 23)
  Error executing configuration script 'AnsConfigFENSAP.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigFENSAP.tcl" line 23)
  Error executing configuration script 'AnsConfigCFDPost.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigCFDPost.tcl" line 23)
  Error executing configuration script 'AnsConfigFLUENT.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigFLUENT.tcl" line 23)
  Error executing configuration script 'AnsConfigPolyflow.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigPolyflow.tcl" line 23)
  Error executing configuration script 'AnsConfigFORTE.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigFORTE.tcl" line 23)
  Error executing configuration script 'AnsConfigRDWorkbench.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigRDWorkbench.tcl" line 23)
  Error executing configuration script 'AnsConfigTG.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigTG.tcl" line 23)
  Error executing configuration script 'AnsConfigSpeos.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigSpeos.tcl" line 28)
  Error executing configuration script 'AnsConfigSpeosLabs.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigSpeosLabs.tcl" line 23)
  Error executing configuration script 'AnsConfigAQWA.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigAQWA.tcl" line 23)
  Error executing configuration script 'AnsConfigACP.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigACP.tcl" line 23)
  Error executing configuration script 'AnsConfigANSYS.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigANSYS.tcl" line 26)
  Error executing configuration script 'AnsConfigMotion.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigMotion.tcl" line 23)
  Error executing configuration script 'AnsConfigClientLicensing.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigClientLicensing.tcl" line 23)
  Error executing configuration script 'AnsConfigAVIEW.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigAVIEW.tcl" line 23)
  Error executing configuration script 'AnsConfigOptiSLang.tcl'
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 13:13:21 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 13:18:19 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 13:50:27 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 13:53:06 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 15:15:11 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 15:29:23 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 15:32:34 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 15:44:55 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Fri Jan 10 17:43:32 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Sun Jan 12 12:56:48 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\config\AnsConfigOptiSLang.tcl" line 23)
Ansys installation: Sun Jan 12 13:59:58 2025
  'C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):Â
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCommonDiscovery.tcl" line 30)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigADR.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCommon.tcl" line 32)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigWB.tcl" line 23)
    Unknown error
  Exit Code: 1
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCFX.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCHEMKIN.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigEnSight.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigFENSAP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigCFDPost.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigFLUENT.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigPolyflow.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigFORTE.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigRDWorkbench.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigTG.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigSpeos.tcl" line 28)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigSpeosLabs.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigAQWA.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigACP.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigANSYS.tcl" line 26)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigMotion.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigClientLicensing.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigAVIEW.tcl" line 23)
    Unknown error
  Exit Code: 1
    while executing
    invoked from within
   set cmdPath ""
   if { ..."
    (file "C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\config\AnsConfigOptiSLang.tcl" line 23)
>>>--------------------------------------->Â
/////////////////////////////////////////////////// INSTALL.LOG
Start Installation: Fri Jan 10 00:05:03 2025
Revision: 2024 R2Platform specifics:
  Windows
Username of Installer: BIG-BOY-JONNY\jonat
User Has Administrator Privileges
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp29396\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp29396 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
Initial mount directory:
Installation Directory:
  C:\Program Files\ANSYS Inc\ANSYS StudentWindows x64
   Design
     Discovery
     Ansys Dynamic Reporting
     CFX (includes CFD-Post)
     Chemkin
     EnSight
     FENSAP-ICE
     Fluent (includes CFD-Post)
     Forte (includes EnSight)
     Model Fuel Library (Encrypted)
     Polyflow (includes CFD-Post)
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
     Discovery Geometry Interface
     SpaceClaim Geometry Interface
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Material Calibration App
     Customization Files for User Programmable Features
     Mechanical Products
     MotionThe installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.You're missing required prerequisites.
Installing MS ASP.NET Hosting Bundle 6.0.23
Installing MS ASP.NET Hosting Bundle 7.0.14
Installing MS ASP.NET Hosting Bundle 8.0.4
Installing MS Desktop Runtime 6.0.23
Installing MS Desktop Runtime 7.0.14
Installing MS Desktop Runtime 8.0.4
Everything was successfully installed.Reading the installation media contents - please wait.
Successfully copied prerequisites from media.You don't need to install any prerequisites.
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\framewrk\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\instcore\tcl\COMMON.TGZ ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\instcore\tcl\WINX64.TGZ ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythnew\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\disco\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\disco_explore\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\disco_overlay_resources\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\apiserver\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\clclient\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\ansoft\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\matdes\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\wb\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\corewb\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\cadaisol\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\cadregistry\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\injmold\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\minerva\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\meshing\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\primemesh\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\python_site_primemesh\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\apipsrv\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\syscplg\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\mechsrvplg\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins_simulationdatamodel\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins_autodyn\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\rsm\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\icemwb\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\turbosys\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\acispara\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\sec\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ccm\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\blademodeler\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\fusion\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ecadxltr\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\spatialiop\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\granta_gateway\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\granta_gateway\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\granta_selector\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\granta_selector\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cff\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluenta\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentc\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentm\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluents\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentp\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent3ddp\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\sgcharts\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fwgfx\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\common\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\commoninstall\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythext\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythcloudext\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\hlp\hlpviewer\HLPVIEWER.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\7zip\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-nvd3\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-ui-context-menu\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angular-ui-tree\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularjs\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularjs-slider\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\angularui\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\bootstrap\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\d3\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\ffmpeg\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\IntelCompiler\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\jquery\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\ngInfiniteScroll\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\nvd3\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\qt\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\signalr\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\hdf5\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\zlib\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\mpi\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ansys\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addgeometry\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\ansys\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\solver\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\data\DATA.GZ ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\apdl\APDL.GZ ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\python_site_mapdl\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\mech\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\dpf\plugins_composites\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aas\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfxcomon\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\stride\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\hoops\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geompara\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\designmodeler\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\artemis\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\lumerical\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\intelmkl2023.1.0\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\nexus\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\openjre\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\spaceclm\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cfx\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\cfx\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\post\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\cfdpost\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\tp\cpprestsdk\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\chemkin\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\chemkin\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ensight\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fensap\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluentu\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent2d\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent2ddp\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\fluent3d\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\fluent\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\ensight_components\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\polyflow\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\polyflow\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\matpro\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\forte\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\forte\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\turbogrd\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\acad\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\cat5\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\datakit\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\osm\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geomproe\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\pe\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\ai\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\geomunig\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\nx\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\revit\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\se\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cads\sw\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speos\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\anscust\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speoslabs\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\speosdata\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aqwa\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\aqwa\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\autodyn\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\autodyn\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\matcal\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addincfg\matdes\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\acp\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\addins\acp\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\shapeoptimization\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\additive_cl\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\motion\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\motion_scdm_addin\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\student\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\license\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\config\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\hlp\hlplic\HLPLIC.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\aview\WINX64.7z ...
 Extraction: C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64\optislang\WINX64.7z ...
RSS is disabledRunning ConfigSpaceClaim -install -discovery_live -create_discovery_shortcut
Finished running ConfigSpaceClaim
Running ConfigCommon -discovery_live -install
Running ConfigADR
Running ConfigCommon -install
Configuring Help ...Running C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe ConfigHelp
  couldn't execute "C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe": no such file or directory
ANSYS Internet Doc has been configured.
Running ConfigWB
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\AnsConfigRSM.exe" -encodingUTF8Configuring RSM...
Configuring default RSM and ARC Port numbers for 24.2 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM 24.2 Configuration...
Creating Start Menu Shortcut for RSM 24.2 Job Monitor...
Creating Start Menu Shortcut for RSM 24.2 Cluster Monitor...
Creating Start Menu Shortcut for ARC 24.2 Configuration...
Creating Start Menu Shortcut for DCG 24.2 Configuration...
Error creating shortcut: There is not enough space on the disk.
Running ConfigSpaceClaim -installFinished running ConfigSpaceClaim
Running ConfigCFX
Running ConfigChemkin
Running ConfigEnSight
Running ConfigFENSAP
Running ConfigCFDPost
Running ConfigFLUENT
Running ConfigPolyflow
Running ConfigForte
Running ConfigRDWorkbench
Running ConfigTG
Running ConfigSpeos
Running ConfigSpeosLabs
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigMotion
Running ConfigClientLicensing
Running ConfigAview
Running ConfigOptiSlang
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"Â
Log files is C:\Program Files\ANSYS Inc\ANSYS Student\CADConfigLogs\v242\Latest\CADConfigurationMgr.log
MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\CADConfigLogs\v242\Latest\CADConfigurationMgr.log
Prerequisites ..... Configure Success
SC  Workbench  PlugIn ..... Not Configured
Discovery Workbench Plugin ..... Configure Success
The installation completed with warnings/errors. Review any .err or .log files in:
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 00:15:58 2025
Start Installation: Fri Jan 10 10:23:54 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27468\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27468 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Configuring default RSM and ARC Port numbers for 2024 R2 ...
Done!
Creating Start Menu Shortcut for RSM 2024 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\RSM Configuration 2024 R2.lnk
Creating Start Menu Shortcut for RSM 2024 R2 Job Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\RSM Job Monitoring 2024 R2.lnk
Creating Start Menu Shortcut for RSM 2024 R2 Cluster Monitor...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\RSM Cluster Monitoring 2024 R2.lnk
Creating Start Menu Shortcut for ARC 2024 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\ARC Configuration 2024 R2.lnk
Creating Start Menu Shortcut for DCG 2024 R2 Configuration...
Created Shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Ansys 2024 R2\Remote Solve Manager\DCG Configuration 2024 R2.lnk
Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\HPCServices\DCG Local Portal.lnk
Created Shortcut C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\HPCServices\DCG Local Shutdown.lnk
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 10:34:23 2025
Start Installation: Fri Jan 10 13:07:46 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6668 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
Successfully created file associations.
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 13:09:00 2025
Start Installation: Fri Jan 10 13:12:09 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35324 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos -removeProgramData
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 13:13:21 2025
Start Installation: Fri Jan 10 13:17:07 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26472 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 13:18:19 2025
Start Installation: Fri Jan 10 13:49:15 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp35396 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 13:50:27 2025
Start Installation: Fri Jan 10 13:51:55 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp23496 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 13:53:06 2025
Start Installation: Fri Jan 10 15:13:58 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp26684 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 15:15:11 2025
Start Installation: Fri Jan 10 15:28:12 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp18092 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 15:29:23 2025
Start Installation: Fri Jan 10 15:31:23 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp30264 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 15:32:34 2025
Start Installation: Fri Jan 10 15:43:40 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp6828 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 15:44:55 2025
Start Installation: Fri Jan 10 17:42:19 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp14788 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Fri Jan 10 17:43:32 2025
Start Installation: Sun Jan 12 12:55:35 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp27876 -launchdir C:\Users\jonat\Downloads\ANSYSACADEMICSTUDENT_2024R2.1_WINX64\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
   Design
     Discovery
     Chemkin
     EnSight
     FENSAP-ICE
     Reaction Workbench
     TurboGrid
   Geometry Interfaces
   Optical
     Speos
   Structures
     Aqwa
     Autodyn
     Mechanical Products
Running ConfigADR
Running ConfigWB
Done!
Running ConfigCFX
Running ConfigForte
Running ConfigTG
Running ConfigSpeos
Running ConfigAQWA
Running ConfigACP
Running ConfigANSYS
Running ConfigAview
C:\Program Files\ANSYS Inc\ANSYS StudentInstallation Complete: Sun Jan 12 12:56:48 2025
Start Uninstallation: Sun Jan 12 13:55:38 2025
  Windows
C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328\instcore.exe -usetempdir C:\Users\jonat\AppData\Local\Temp\ans_install_tmp15328 -launchdir "C:\Program Files\ANSYS Inc\ANSYS Student\v242" -admin -uninstall
  C:\Program Files\ANSYS Inc\ANSYS Student\v242\installer
  C:\Program Files\ANSYS Inc\ANSYS StudentDesign
   Discovery
   Chemkin
   EnSight
   FENSAP-ICE
   Reaction Workbench
   TurboGrid
Geometry Interfaces
Optical
   Speos
Structures
   Aqwa
   Autodyn
   Mechanical Products
   MotionReading the installation media contents - please wait.
 Extraction: C:\Program Files\ANSYS Inc\ANSYS Student\v242\installer\instcore\tcl\COMMON.TGZ ...
 Extraction: C:\Program Files\ANSYS Inc\ANSYS Student\v242\installer\instcore\tcl\WINX64.TGZ ...
Processing selections for uninstall ...
 Attempting to terminate running processes whose images will be removed ...Successfully unregistered DLLs...
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe" -unconfigure_specified
Running UnconfigSpaceClaim -install -discovery_live -create_discovery_shortcutFinished running UnconfigSpaceClaim
Running UnconfigCommon -discovery_live -install
Running UnconfigADR
Running UnconfigCommon -install
Unconfiguring Help ...Running C:\Program Files\ANSYS Inc\ANSYS Student\v242\commonfiles\configs\winx64\config\AnsConfig.exe UnconfigHelp
Running UnconfigWB
Running "C:\Program Files\ANSYS Inc\ANSYS Student\v242\RSM\bin\AnsUnconfigRSM.exe" -encodingUTF8User has Administrator privileges
Unconfiguring RSM...
Running UnconfigSpaceClaim -installFinished running UnconfigSpaceClaim
Running UnconfigCFX
Running UnconfigChemkin
Running UnconfigEnSight
Running UnconfigFENSAP
Running UnconfigCFDPost
Running UnconfigFLUENT
Running UnconfigPolyflow
Running UnconfigForte
Running UnconfigRDWorkbench
Running UnconfigTG
Running UnconfigSpeos
Running UnconfigSpeosLabs
Running UnconfigAQWA
Running UnconfigACP
Running UnconfigANSYS
Running UnconfigMotion
Running UnconfigClientLicensing
Running UnconfigAview
Running UnconfigOptiSlang Beginning file removal ... ...
C:\Program Files\ANSYS Inc\ANSYS StudentUninstallation Complete: Sun Jan 12 13:59:58 2025
<---------------------------------------<<<Â
January 13, 2025 at 11:19 am
Rajeshwari Jadhav
Ansys EmployeeHi,
Please disable your firewall/antivirus and try installing again,the error shows tcl, which is caused due to firewall/antivirus.
May I know from where did you download the package? Also rename the Ansys folder (%appdata%) and .ansys folder (%temp%) to Ansys.old and .ansys.old respectively.
- acces to path ‘session_files’ is denied error
- unexpected license problem; exiting. hit return to exit.
- critical error during installation of 24 R2 version
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Can not find Spaceclaim option in ANSYS2024R2 workbench
- Workbench application not showing up after installing Ansys Student 2024 R2
3029
971
858
836
777
