December 6, 2024 at 10:26 pm
giron9349
SubscriberGood morning,
Where can I enter the major and minor diameter, inlet and outlet edges of a Francis turbine in BladeGen? Or, in which interface within ANSYS would it be easier to do so? Please help -
December 6, 2024 at 11:11 pm
rfblumen
Ansys EmployeeThe Deswirl Vane template in BladeGen can be used as a starting point for a Francis turbine runner design. You can specify in the Initial Meridional Configuration Dialog window of the template the inlet radius and outlet hub and shroud radiialong with the z coordinates.
1565
1386
1242
