Increasing the quality of a thin surface
    • kuumbara
      Hi all,
      I got a tube with a small hole at the upper part. The tube is hollow, with 0.05mm of thickness. I meshed the body and I did it. But, the Element Quality result is so bad (average 0.03). Is anyone know how to increase the quality of a thin surface/thin body? Or is it okay if I have very bad quality for the thin surface?
      Open the geometry in SpaceClaim. On the Prepare tab, use the Midsurface button. This will replace the solid body with a surface body that will automatically be assigned a thickness of 0.05 mm. If you got a single surface body with multiple faces, you can close SpaceClaim. If you get multiple surface bodies, on the Workbench tab, click the Share button, then you can close SpaceClaim. When you mesh that geometry in Mechanical, you will get very high quality shell elements instead of very low quality solid elements.
      • n2390n
        hi peteroznewman:
        does DesignModeler has same feature? cuz my model quite small (~0.15 um & 15um)
        spaceclaim can't support in specific size when it’s come to nm
          Yes, DM has Midsurface. It is less automated that SC.
          It is easy to select units of um in DM, but not nm.
          It is possible to select units of nm in SC.  Go to File > SpaceClaim Options and select Length scale: Small, then Length: Nanometers.
        • n2390n
          THX alot mate
          I'll try that feature
      • kuumbara
        Hi Peter,
        After I apply "Midsurface" to the geometry, I got 1 surface body and the solid body is automatically suppressed. I meshed the surface body, got amazing mesh quality. But when it is imported to Fluent System, there is a warning saying "This Appear to be a Surface Mesh. Surface Mesh cannot be read under /file/read-case functionality". Do you know how to solve it?
          Hi kuumbara,
          Your description of the hollow tube and the channel you posted the discussion in (General Mechanical) led me to believe you were talking about a structural analysis, not a CFD analysis.  The warning is accurate, a 3D surface mesh is not very useful to Fluent.
          Does this hollow tube with the small hole in one end contain a fluid volume that you want to solve for fluid flow in Fluent?  Once you have solved the fluid flow model, do you want to apply the pressure load to the structural hollow tube model to understand the stress in the tube caused by the fluid boundary conditions?
          Fluent needs a solid body in the shape of the inside of the hollow tube.  Use SpaceClaim's Volume Extract button on the Prepare tab to create that solid then set the hollow tube solid to Exclude for Analysis so that only the fluid volume gets sent to Fluent for meshing.
          Can you describe the results you actually need and the boundary conditions on the model?
    • kuumbara
      It works! Thank you Peter! All this time I use DesignModeler, that's why I didn't see the menu/setting similar to "Midsurface" in SpaceClaim.
