October 8, 2025 at 11:26 pm
muhammadfaraz.mahmood
SubscriberWhen I rotate the aerofoil in 2D simulation and give inlet velocity in just x axis, the lift and drag forces are coming correct.
However, if I leave the aerofoil at 0 degree AOA, and change the velocity into x and y component through cos and sin (AOA), the results are not coming correct.
I have tried meshing in C type, but still cant figure out where is the problem, I mean dont understand why my x and y component velocities are giving wrong results. I have been trying since 2 months but couldnt figure out. I hope if some one can guide me.
Thanks -
October 9, 2025 at 8:03 am
Petros
Ansys EmployeeHello, have you used the correct force vectors for the report definitions in the second case?
October 9, 2025 at 8:52 am
Subscriber-
October 9, 2025 at 9:21 am
Petros
Ansys EmployeeAs said, you need to use the correct values for the force vector in the lift report definition panel. In order for the 2 setups to agree, the x and y components have to be taken at the correct coordinate system.
- affinity not set
4047
1461
