November 13, 2025 at 9:03 am
paul pladet
SubscriberHello,
A customer experienced issues regarding dimensioning while opening files in 2025. Some have moved and other dimensions have selected incorrect edges.
Made and opened in 2024 (everything is correct):
Opened in 2025 (dimensions have been moved and incorrect dimension values):
As you can see SpaceClaim 2025 selects the incorrect side of a small fillet, causing the dimension to change 0,02.
Can this be solved?
Viewing 0 reply threads
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
1488
1363
1195
