March 18, 2026 at 4:12 pm
cesarj.95plus
SubscriberDear support,
I am trying to import a 2D geometry from CATIA to ANSYS FLUENT meshing but I cannot import into ANSYS the names of the edges, only the faces/surfaces. I've done the following steps
- I've create a simple 2D cylinder in CATIA and named their edges using publications (I didn't use the extracts in the screen)
- I've imported the CATPart into spaceclaim without issues
- But when I import the spaceclaim file into Fluent meshing, the names disappear
Regarding the configurations I've followed the recommended steps that I could find on the web:
I have also followed the solutions provided in the following links but none of them helped me to import the edges names
https://innovationspace.ansys.com/knowledge/forums/topic/how-can-i-transfer-named-selections-from-my-cata-v5-model-via-spaceclaim-to-fluent-meshing/
https://youtu.be/QMh-kc9mHL4?si=vFKJYkvCi5IW9mTB
I am using ANSYS Student 2025 R2 and CATIA V5-6 R2020 (B30) and I am unable to make ANSYS Fuent recognise the published edges, making it impossible to start meshing without having to rename everything again. I know that it is a simple case and I could rename everything easily in SpaceClaim but I don't want to go throught it every time if the CAD is extremely more complicated. Could someone provide assistance with this?
Thank you in advance!
March 25, 2026 at 3:41 pm
cesarj.95plus
SubscriberThere isn't any native from to import edge names fromÂ
.CATPartinto SpaceClaim?
5879
1306
