July 18, 2025 at 9:18 am
arun.tv
SubscriberHi,
Consider a ring of 50mm outer dia and 25 mm inner dia. and a thickness of 5mm. I want to achieve a uniform lighting across the 5mm thickness. only this area is visible from outside.
I was thinking about placing LEDs (625nm) through out the inner surface (LED facing the ring)
My question is , How do I visualize/Analyze the irradiance across the ring edge.Though I use Polar detector, I am not confident about the results provided by that option.
Thanks in advance,
Arun
July 21, 2025 at 1:45 pm
Niki Papachristou
Forum ModeratorHi Arun,
Thank you for reaching out to us! Its a little bit hard to understand your system here, a screenshot might have been useful!
On the other hand, I think a good alternative for your case would have been to use the "object as detector" option. You can read more about that on these posts: How to view results for Object set as Detector?, A collection of information about "Objects as Detectors".
Let me know if these covered your questions or you need further assistance.
Kind Regards,
Niki
6395
