April 21, 2026 at 10:11 am
wakai.kaiki.q2
SubscriberWe are performing ultra-high-speed impact analysis using Autodyn's SPH method.
The projectile's impact velocity is 7 km/s, and typically, the impacted object liquefies upon impact.We are performing ultra-high-speed impact analysis using Autodyn's SPH method.
The projectile's impact velocity is 7 km/s, and typically, the impacted object liquefies upon impact. We would like to perform a simulation using a resin material as the impacted object. When I perform a collision analysis using the polyethylene material included in Autodyn by default, the polyethylene scatters, which differs from the actual phenomenon. In reality, due to the material’s property of melting at high temperatures (viscosity), material remains around the impact area of the impacted object. My question is: Please tell me how to set the material’s viscosity in Autodyn.
April 24, 2026 at 5:32 am
Ashish Khemka
Forum ModeratorHello,
Synopsys employees cannot answer this query. Please wait for other members to chime in.
Thanks and Regards,
Ashish Khemka
June 12, 2026 at 7:31 am
terrycarson107
Subscriber@fnaf 4 To give a more specific recommendation, could you tell me:
- Which version of Autodyn are you using?
- Are you using:
- SPH only?
- SPH-to-SPH impact?
- SPH projectile + Lagrange target?
- Which EOS and strength model are assigned to the polyethylene?
6835
1343
1152
