How to link Step End Time and Time Step to engine RPM Parameter in RBD
    • zx768160
      I am using RBD of an engine crankshaft system as an initial model to calculate forces exerted on a crankshaft for detailed component modelling of the crankshaft. I need to do this across the range of RPM which has been parametrised in workbench. I need to calculate for two rotations of the crank to allow for a full engine cycle but RBD won't allow me to directly parametrise the Step End Time and the Time Step to reflect the changing values for each RPM. Can I have some help on the work-around to resolve this?
Viewing 0 reply threads
