TAGGED: ansys, petroz, question, spaceclaim, static-structural
April 16, 2025 at 6:51 am
muhd.safwan78
SubscriberStatic structural analysis on lumbar spine
What easiest way to develop the ligament for human spine L4 L5? using Line bodies beams covert it to truss or links. or using spring element as ligament. or have another way to develop the ligament.
if anyone have done this before, can share how you do it.
April 16, 2025 at 12:29 pm
Dennis Chen
SubscriberHello, there are actually a lot of papers out there that explained how this is done so do some quick searches.  I've used a series of discrete elements (mat_nonlinear_elastic_discrete_beam) in one of my project with the author of this dissertation:  https://biomed.drexel.edu/implantcenter/CV-Dissertations-Thesis/steven-rundell-dissertation.pdf
hope this helps you and Steve is Awesome!Â
April 21, 2025 at 8:43 am
JohnSoliz99
SubscriberÂ
@Geometry Dash Lite The easiest and most common way to develop a ligament model is to use spring elements, because biological ligaments behave much like a nonlinear spring that can stretch and absorb loads elastically. Spring elements allow researchers to easily assign stiffness and deformation parameters that match real biological data, and are easy to integrate into finite element models.
5809
