April 10, 2026 at 5:54 pm
javat33489
SubscriberHello everyone.
I have two cylinders nested inside each other. The inner cylinder (red) is 300 mm in diameter, and the outer (black) is 2 mm thick.
Both cylinders are made of SPH particles.
How can I configure the outer cylinder to have a single layer of the specified size, for example, a 2 mm thick cylinder? The system won't let me build particles on the outer cylinder larger than 0.05 mm, resulting in a total particle count of over 3 million.
Thank you. -
April 23, 2026 at 3:09 pm
