February 18, 2026 at 9:47 am
yogesh.babu
SubscriberHello,
1. Is there a way to implement a time-dependent variation, specifically a sine variation, on top of the EM losses computed from HFSS, while running an electrothermal simulation in Ansys Icepak AEDT?Â
2. Is it correct to include an expression of a sine function like sin(2*pi*f*Time), with f = 217 Hz, directly in the loss multiplier field?
I tried a few simulation trials, but I was not successful in getting a meaningful result. A brief explanation of my simulation workflow:Â
- I model a simple microstrip line in HFSS. Compute the dielectric (substrate) losses using the fields calculator. The dielectric losses are 0.99 mW at 5 GHz when 1 W power is given as input at the port.Â
- I insert an Icepak design (transient problem type) within the same project and copy the model from HFSS to Icepak with thermal properties included.
- Assign an EM loss Boundary Condition (BC) to the dielectric. A link between HFSS & Icepak is created. In the loss multiplier field, I add a sine function as shown in the screenshot below.
  4. I add a monitor point on the top surface of the dielectric to check the temperature rise over time.Â
  5. Create a solution setup, generate mesh, and run the simulation. Simulation runs from 0s to 23ms in time steps of 0.18ms. The resulting temperature over time is shown below.
A screenshot of the full model is shown for your reference. I use Ansys version 2024 R1. Any inputs on this are highly appreciated.
Thanks,
Yogesh
5179
1838
1387
1249
