November 24, 2025 at 7:32 am
November 24, 2025 at 8:02 am
Essence
Ansys EmployeeHello,
Currently, using the Report Plots will show the time from the calculation from where it was stopped. You can clear the data if you want by Report Plots > RMB > Clear Data. But this will still continue from the time step you have previously simulated.
November 24, 2025 at 8:43 am
Petros
Ansys EmployeeÂ
Hi, you can use the (rpsetvar ‘flow-time 0) command.
https://innovationspace.ansys.com/knowledge/forums/topic/how-to-reset-flow-time-for-unsteady-calculation/
November 24, 2025 at 9:13 am
Forum ModeratorTo clarify, did you intend to start the run at 0s or do you want to display the plot from 0s? Fluent can save monitors to a file, but only retains 1000 by default with the data file. The above comments both answer what you've asked, but I'm not sure you've asked for what you want.Â
- affinity not set
4352
1494
1375
1197
