TAGGED: convection, discovery, fluent, jacket, mixing-chamber
March 20, 2025 at 7:35 pm
tjhidalgo
SubscriberHello,
I am trying to simulate a jacketed mixing tank at cold temperatures. I am not sure as to why the solved temperatures of the inside tank appear to be so high. It is probably the way I have the simulation set up but I am not sure. Please help! Any ideas are much appreciated.
Also I am not familiar with what 'Convection (default)' exactly referring to.
Thanks!
March 24, 2025 at 9:42 am
Devendra Badgujar
Forum ModeratorHi,Â
From the description and image it looks like the problem is with capturing the details inside. Are their any blades or rotating solid in the mixing jacket? If that's the case you will need to make sure the detials are captured correctly to get correct results.Â
You can refer this https://innovationspace.ansys.com/courses/courses/conjugate-heat-transfer/lessons/meshing-in-explore-lesson-3/ to learn hot to mesh in Explore. Conjugate Heat Transfer Using Ansys Discovery Software | Ansys Courses
For default convection condition, Discovery will create this condition as a fluid in contact with those faces where the convective heat flow with surrounding fluid.Â
DevendraÂ
- Unable to attach geometry 2024 R2
- Data Center Simulation
- [SpaceClaim] STEP file size using Converter.exe
- How to do the snap fit insertion FEA?
- Spaceclaim 2024 error FNE activation failed
- Ansys Discovery Crashing vGPU (Reproducible)
- PMI Product manufacturing information in SpaceClaim/Discovery modeling
2773
960
835
599
591
