August 2, 2025 at 11:31 am
nitkum221
SubscriberI am currently working on a simulation involving laminar fluid flow and heat transfer analysis through a porous structure. To achieve this, I have designed an enclosure around a porous model. The working fluid is water, and the solid material is titanium.
However, I am facing an issue in ANSYS Fluent: I am unable to assign separate material properties for the fluid and the solid. In the Cell Zone Conditions, it only shows a single body, and I cannot apply materials separately for the fluid and solid domains.
Could you please guide me on:
How to assign fluid and solid material properties separately?
Whether the parameters I’ve used are appropriate for performing this simulation?
I have shared the design and Fluent setup files via Google Drive (link attached).
https://drive.google.com/file/d/1xNZeHOtbwjATooSGIUaqPnOo6Fk2m0TN/view?usp=sharing
Simulation Parameters
A) Models
Energy: On
Viscous: Laminar
B) Materials
Fluid: Water
Solid (Wall): Titanium
C) Cell Zone Conditions
Issue: Only a single body appears — cannot assign separate solid material
D) Velocity Inlet
Velocity Specification Method: Magnitude, Normal to Boundary
Reference Frame: Absolute
Velocity Magnitude: 0.0001 m/s
Initial Gauge Pressure: 0 Pa
E) Pressure Outlet
Pressure Profile Method: 1
Backflow Direction Specification Method: Normal to Boundary
Backflow Pressure Specification: Total Pressure
F) Wall Conditions
Boundary: Stationary Wall
Shear Condition: No Slip
Wall Definition: Same as Boundary
G) Reference Values
Area: 5e-06 m²
Density: 1000 kg/m³
Characteristic Length: 0.0121 m
Pressure: 0 Pa
Temperature: 288.16 K
Velocity: 0.0001 m/s
Viscosity: 0.001 kg/(m·s)
Specific Heat Ratio: 1.4
Y+ for Heat Transfer Coefficient: 300
H) Solution Methods
Scheme: SIMPLE
I) Solution Controls
Pressure: 0.3
Density: 1
Body Forces: 1
Momentum: 0.7
J) Residuals
Absolute Criteria: 1e-05
Iterations: 1000
August 2, 2025 at 3:23 pm
peteroznewman
SubscriberI wouldn’t use the word porous to describe this model as that word has a specific meaning that doesn’t apply to your description. Titanium is not porous for water, the flow is around the titanium body, not through it. The hole down the middle is still outside the titanium body. What you have is simply a block of titanium with large holes in it.
To fix the problem of only one body transferring, open the geometry in SpaceClaim and look at the Structure window on the left. Under FFF-2 you will see the Solid with holes was automatically set to Suppress for Physics when the fluid Enclosure was created. Right click on Solid and select Activate for Physics.
One choice you can make before you leave SpaceClaim is whether you want additional Interfaces created in Fluent on the 22 faces where water touches titanium. I don’t think you need that, but maybe someone with more experience will chime in with a reason why you do. One reason is to use a fine mesh on the fluid and a coarse mesh on the solid. The interface allows non-matching cell faces to transfer the heat. If you use the Share button, the cell faces match at the surface for heat transfer to take place.
If you want mesh interfaces, close SpaceClaim and when you open the Mesh app, you will find an automatically generated Contact Region that Fluent will be able to use as Interfaces.Â
I generally want to avoid any extra items in Fluent. In SpaceClaim, go to the Workbench tab and click the Share button and close SpaceClaim. When you open this is Mesh, there will be no Contact region and no extra boundary condtions will show up in Fluent.
Now open the Mesh cell, which will reread the geometry and you will have two bodies. One can be set to Solid and the Enclosure can be set to Fluid.
August 2, 2025 at 6:03 pm
nitkum221
SubscriberThis is not the actual porous model; I have created a general model because I don't want to share the original file. Secondly, we need to assign material properties such as titanium or aluminum to this model in order to perform fluid flow and heat transfer analysis.
Thirdly, as you mentioned, if we need to import both the enclosure file (which contains the model) and the solid model (from which the enclosure was created) into Fluent, how can we analyze fluid flow and heat transfer in the same body? Could you please perform the analysis or share a reference image/ analysis file for better understanding?
August 2, 2025 at 8:04 pm
peteroznewman
SubscriberTo fix the problem of only one body transferring, open the geometry in SpaceClaim and look at the Structure window on the left. Under FFF-2 you will see the Solid with holes was automatically set to Suppress for Physics when the fluid Enclosure was created. Right click on Solid and select Activate for Physics.
To learn how to create a Porous Zone, open the Ansys Help system, go to the Fluent Tutorials section and read Chapter 3. Modeling Flow Though Porous Media.
3587
1193
1086
1068
952
