TAGGED: harmonic-acoustic, harmonic-acoustics, harmonic-force, inverter, nvh, nvh-analysis, pwm
February 11, 2026 at 3:52 pm
abdullah.sharaf
SubscriberHello,
i set up a Workbench project, that enabels analysis the harmonic response in Ansys mechanicel coupling with Ansys Maxwell for an electrical motor. The forces are calculated in Maxwell with PWM supply, with a switching frequency of 15 kHz.
I followed all steps in the following help document, but i could not see the sidebands interpolation due to the PWM switching effect in the ERP diagram.
https://ansyshelp.ansys.com/public//Views/Secured/Electronics/v242/en/Subsystems/Maxwell/Maxwell.htm#InverterFeedbackHarmonicForce%20Coupling.htm?TocPath=Maxwell%2520Help%257CMaxwell%2520Coupling%257CMaxwell%2520Multiple%2520RPM%2520Harmonic%2520Force%2520Coupling%257C_____1
i want to ask if this feature "Harmonic Force Coupling for Inverter-Fed Machines" was already tested from Ansys? Because i do not see any example shows the result of the implemented feature.
best regards,
Abdullah
February 17, 2026 at 10:24 pm
MirandaH
Ansys EmployeeYes, this feature Harmonic Force Coupling for inverter‑fed machines is tested and implemented.
February 18, 2026 at 8:29 am
5179
1838
1387
1249
