Electronics
Electronics
Got any faster or perfect ways to see the Electric field between two electode?
    • ngv-wg22
      The things now I create a box and assign it as an Oil, and create two hemisphere electrode to act as the ASTM D1816 test method. In the Simulation, I set one side of the electrode is 60kv another side is 0kv because I want to see the breakdown voltage occurs or not but the things is I want to see the Electric field. I got do two version for seeing the Electric field can help me see it the way that I set for investigate the Electric filed correct or not? Or you got a way to see the Electric field faster
    • Takeshi Itadani
      Dielectric breakdown cannot be checked with HFSS or Maxwell.
      With Ansys Charge Plus, air dielectric breakdown and charging of dielectrics can be checked.
