April 7, 2026 at 8:49 pm
Sanjeev.mehta
SubscriberWe are trying to get Force Spectral Density (in N or lbf) against frequency results from Random Vibration analysis. Can this be achieved using APDL? Would you be able to guide us with a script or example to get these results? -
April 8, 2026 at 1:33 pm
dlooman
Ansys EmployeeWould this be the same as a force Response PSD? The units of that are N^2/hz. A characteristic of a force response psd is that if you integrate it and take the square root of the integral you get the 1 sigma value of the force associated with the input psd. In the APDL postprocessor POST26 any quantity can be used to create a response psd. So for example, the commands below perform a simple psd analysis and then produce a response psd for the FY reaction force. If you are creating a commands object in Workbench Mechanical you would only need to use the commands starting with /post26.
/prep7et,1,188sectype,1,beam,rectsecdata,1,1mp,ex,1,3e7mp,nuxy,1,0.3mp,dens,1,0.000754n,1n,2,40e,1,2d,1,allfini/soluantype,modalmodop,lanb,2mxpand,2,,,yessolvefini/soluantype,spectrumspopt,psd,,yespsdunit,1,acelpsdfrq,1,1,10,100psdval,1,1000,1000psdres,disp,reld,1,uy,1.0dmprat,.05pfact,1psdcomsolvefini/post26store,psd,10rfor,2,1,F,Yrpsd,3,2/show,pngplvar,3-
April 8, 2026 at 2:31 pm
Sanjeev.mehta
SubscriberThanks for the response. We are trying to get the response in N/Hz units, which might be reaction force from nodes as function of frequency response.
April 8, 2026 at 2:37 pm
dlooman
Ansys EmployeeCan you provide a reference that explains the meaning of a quantity like N/Hz? Is it like an FFT result where you get the force content in bins of a certain frequency width?
April 8, 2026 at 8:09 pm
Sanjeev.mehta
SubscriberApologies, I take that back. We are looking for N^2/Hz. Thanks.
April 8, 2026 at 8:20 pm
dlooman
Ansys EmployeeOK, good!
5984
1307
