Force results in MPC184 elements vs Frequency in Random Analysis
    • nicolas.cuello
      Hi all.
      I would like to know if there is some way to extract the forces vs frequency in a random analysis.
      I have solved a modal analysis first in my model and I have found the resonance frequencies, then i solved a random analysis. Now, i want to know the forces in several bolts conections (modeled with a 1D beam + MPC) in function of the frequency to study which frequecies have most impact in the bolts conections.
      Is there a way in ANSYS Workbench or with some command in APDL to extract this information?.
      Thanks.
      Nicolás.
    • dlooman
      You mention MPC184, but it sounds like you want results for an ordinary beam element.  If Mechanical is creating results for these elements (not a given), then you can use APDL commands like these:
      /POST26
      ESOL,2,Element_Number,,SMISC,1
      RPSD,3,2  ! Force RPSD
      /SHOW,PNG
      PLVAR,3
