March 26, 2025 at 6:22 pm
robb.raffaelli
SubscriberI have a very simple 3 turn H field generating antenna that is coax fed. I keep all parameters and geometry IDENTICAL, but it seems that runs always give different H field plots. I cannot get consistency in my plotted fields. Is there a specific type of mesh setup I need to consider placing around my H-field generating loops where I am looking for field consistency?
March 27, 2025 at 9:02 am
Takeshi Itadani
Ansys EmployeeWhat product are you using? For HFSS, if you are plotting the H field, we recommend that you turn on Solve Inside on the conductor object to include the interior in the analysis. We also recommend adding Mag_H to the convergence condition in the Expression Cache in Solution Setup.
1891
1419
